PLEASE HURRY!!! - in the middle of TB BYPASS
doing a TB BYPASS right now on my 95 Z and wanted to double check that the second hose you disconnect is the small (about 3-4" long 90 degree bent hose coming from a small metal pipe. Your help would be greatly appreciated!!!!!!!!!!!1
Re: PLEASE HURRY!!! - in the middle of TB BYPASS
its all the more easier if you look at it as "i am bypassing the throttle body" instead of disconnect wire that looks like a do-hickey...
all you are doing is connecting the tube that puts coolant into the TB to the tube that the coolant goes out of. basicaly cutting the TB out
Compliments of shoebox' Tech Page..
http://csce.uark.edu/~jgbertr/rb/tb_bypass.jpg
