please help! stuck on tranny removal
Old Apr 5, 2003 | 06:59 PM
cop01's Avatar
I need to get off the tranny cooler lines from the tranny itself. What is a good way to get them. Ive lowered the tranny as much as I can and still cant get a line wrench to grab. Is there anything Im missing? I cant do anything till this is done. thanks in advance.
Chris
Old Apr 5, 2003 | 07:18 PM
dnz28's Avatar
Ok I am up to removing the bell housing bolts. But I think I can help. I just bent the lines alittle and get a long wrench (cut one and put the small end into a piece of pipe) then hook up and pushon the f#$@er and push like mad it took me near two hours about a hour a line.
Old Apr 6, 2003 | 06:30 PM
cop01's Avatar
I couldnt get the lines off and thats the only thing holding me back from getting this bastard out so I can actually drive it again.... My line wrenches kept slipping and almost started to round off the 1/2 inch nut. So I got a pair of vice grips and turned it a little but it twists the steel line too. so I dont know what to do now and Im so frustrated. Any suggestions?......Anyone?
Old Apr 6, 2003 | 06:44 PM
94FlamdS10Blazr's Avatar
almost sound like time to cut em and run a soft line!
Old Apr 6, 2003 | 06:52 PM
joeSS97's Avatar
Roger that.
Old Apr 6, 2003 | 07:05 PM
FastZinTennessee's Avatar
Disconnect the tranny cooler lines from the mounting points around the oil pan, drop the tranny down as much as it will go, then you can get a better angle on the bolts. I read this thread yesterday, and helped a buddy pull my tranny today, that's all we had to do.
John
Old Apr 6, 2003 | 08:00 PM
well a sawzall is my favorite tool so I might be a little biased
Old Apr 6, 2003 | 08:25 PM
cop01's Avatar
thanks for your replies. How hard would it be to run soft lines (and how hard on my wallet?) And since Im going to install a tranny cooler do I have to change those anyway?
Old Apr 6, 2003 | 08:43 PM
Z28ROC's Avatar
You could probably just cut the lines, then splice them back together with fuel injection hose and clamps.
CGM2010CAMARO
Apr 7, 2015 07:44 PM
BigWil
Mar 29, 2015 12:24 PM
mattszm6
Dec 14, 2014 07:09 AM
tds1213
Nov 27, 2014 12:55 PM
Mikes 1994 z28
Nov 25, 2014 02:00 PM
