Please help me identify what's missing.
Old Mar 13, 2010 | 09:40 AM
White1995's Avatar
Finally got the oil leaks fixed on my LT1, and found I'm apparently missing a hose or something from under the throttle body. It looks pretty rusted, so it's obviously been gone a while, but can someone look at the pic and see if you can tell what I need (and if it's important)?
Thanks,
Rob
Old Mar 13, 2010 | 09:49 AM
lt11994's Avatar
That appears to me to be the coolant inlet on the bottom of the throttle body. Most guys who do the throttle body bypass simply cap that off along with a similar looking one thats on the left side of the throttle body and connect the two coolant hoses together. Heres a site that explains it all. Someone probably already did it if it isnt leaking coolant however.
http://timney.cz28.com/tbbypass.htm
Old Mar 13, 2010 | 09:54 AM
flexus's Avatar
Yep that's right, couldn't be anything else that low than the coolant pipe from the TB. You should spray it with some rust penetration spray and cap it.
Old Mar 13, 2010 | 10:12 AM
White1995's Avatar
Guess I gotta check it now to make sure it was done properly, considering the previous owner did some other questionable maintenance.
Thanks for the quick responses though - I was a little concerned when I discovered this.
Old Mar 13, 2010 | 10:22 AM
ChevalierSS's Avatar
I think that hose you see in the top-left corner of the picture was originally connected there... looks like the TB was by-passed. Doesn't look like you have anything to worry about.
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
jayblev95
Sep 26, 2015 09:44 PM
dkred94z
Aug 20, 2015 03:09 PM
cjamen
Jul 27, 2015 12:48 PM
ducttape1975
Jul 10, 2015 06:29 PM
