please help low coolant light
Old Jul 23, 2009 | 08:05 PM
  #16
dragginS10's Avatar
Originally Posted by Injuneer
P0420 sets when the Bank 1 after-cat O2 sensor voltage swings approach 90% of the pre-cat sensor voltage swings. Swap the two after-cat O2 sensors side to side. If the problem follows the sensor (P0430) its a faulty sensor. If the problem stays on Bank 1, its one of the other 3 causes.
so if after i switch them and the SES light is still on then that means my sensor is bad?
Old Jul 23, 2009 | 09:36 PM
  #17
No.
If you swap them, and the SES light stays on, it could be because you have P0420 or P0430, so it won't tell you anything. As I indicated already, you have to read the code to see where the problem is.
calaban
May 18, 2020 06:43 PM
silvermansteve
Mar 4, 2015 05:02 PM
MattFick
Feb 15, 2015 10:16 PM
Jan 23, 2015 01:13 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
