Please help with header install, need all your advice.
Old May 11, 2005 | 02:50 AM
keng's Avatar
Hey guys I am going to install my FLP long tube headers tomorrow, but need your advice on where to start. Do I take off what I can with the car in the ground then jack it up, or do I just put in on jack stands to begin whth.
Then what?
I will also be changing plugs and wires.
Old May 11, 2005 | 08:17 AM
94zgreenmachine's Avatar
Re: Please help with header install, need all your advice.
I would jack the front end up onto stands and disassemble what you could. In fact, I did my entire swap that way. It is a little easier on the back and the back side of the legs, but I was still sore the next morning. If you practice yoga, then bonus for you Just be prepared to get creative when you are having a hard time accessing some of the bolts. Lots of swivels and extensions will help. Good Luck
Old May 11, 2005 | 10:11 AM
NBred94's Avatar
I would say start with it jacked up in the air. There is so much that you will need to get at from both sides that you will soon need to get under the car anyway. I had to jack mine up to get the K&N FIPK off, which was close to the first thing that I did.
Your results may vary.
Old May 12, 2005 | 05:27 PM
keng's Avatar
Ok I am stuck on 2 bolts I can not get.
The passenter side very first bolt by the altenator and the very last bolt.
How do I get these?
Old May 12, 2005 | 05:34 PM
blaze309's Avatar
I think i also had trouble getting the first bolt off on the passenger side because of the ac lines or something. I'm pretty sure i used a ratchet with a small extension and a swivel on the end, the hard part is gettin the socket onto the bolt with that setup it took me a while. As far as the bolt in the back i don't think i had any trouble with that one so i don't know what to say. Just try a combination of extensions,deep and shallow sockets, swivels and anything else you have.
Edit - ya you have to pull off the altenator i thought you already did that.
Old May 12, 2005 | 05:35 PM
Dave89IROC's Avatar
well, the front one, remove the alternator, the rear one, good luck, maybe from underneath after pulling the starter?
Old May 12, 2005 | 05:39 PM
FIREHAWK #7's Avatar
what he said....
Old May 12, 2005 | 07:42 PM
keng's Avatar
Guys I did remove the altenator, I still can'nte get it. I have waisted hours.....
and the bolts are still there.
Old May 12, 2005 | 07:51 PM
MyTMous's Avatar
I removed the old y-pipe, the starter, and the alt.
get the back bolt from under the car.
the front one, from the top, I removed the AIR tube also, made it
alot easier. I used a torque wrench a small socket and a swivel
to get to it, that bolt has a nut and the bolt is a stud on mine,
it holds the alt bracket on also.
good luck.
jj_burchiel
Mar 21, 2015 12:51 AM
jj_burchiel
Mar 5, 2015 07:05 AM
Jlo
Feb 23, 2015 12:20 PM
dmcdonald96
Jan 30, 2015 06:46 AM
