Please help with header install ASAP
Old Mar 27, 2004 | 05:48 AM
  #16
Z95m6's Avatar
i'm pretty sure at the very least the bolt that holds the shaft on will rub. I'd say it might be motor mounts. I'll look at my Z in the morning. I have SLP's that have the same design on the front primary i'll look at how much clearance i have.
Old Mar 27, 2004 | 08:48 AM
  #17
IrocSS85's Avatar
Id try grindin down the shaft first. if the bolt hits, then you cant really do anything about that. poly motor mounts will raise some over stock mounts, and will raise even more if your stockers are worn/sagging. think I'll get hookers instead of dealing w/that. lets see a pic when you figure it out and get it to clear.
chris
Old Mar 27, 2004 | 09:11 AM
  #18
scoobysnax83's Avatar
I've seen closer, you should be fine. Try it before you bend them. Are those coated or do they come like that? They look pretty nice. How much are the pacesetters going for?
Old Mar 27, 2004 | 12:08 PM
  #19
Cmr0z28's Avatar
I bolted the shaft on today, and turned the wheel.....it fits fine, and doesn't rub. They're ceramic coated.
Old Mar 27, 2004 | 12:30 PM
  #20
Hawk's Avatar
Good thing it fit, so did mine BUT when you get on it when your driving and the engine torques it hit in mine. I fixed this by grinding the shaft down a little. Worked for me.
Brian
Old Mar 27, 2004 | 01:48 PM
  #21
95_LT1_6SPD's Avatar
get the passenger side in?
Old Mar 27, 2004 | 04:09 PM
  #22
lol, trust me we'll know when he starts that project
Old Mar 27, 2004 | 04:16 PM
  #23
Cmr0z28's Avatar
actually, the passenger side header slid in fairly easily w/some wiggling....all I had to do was get the car up a few extra inches off teh jack stands. No K-member grinding or motor jacking involved
Old Mar 28, 2004 | 05:11 AM
  #24
you suck...
Old Mar 28, 2004 | 09:10 AM
  #25
Cmr0z28's Avatar
Jlo
Feb 23, 2015 12:20 PM
dmcdonald96
Jan 30, 2015 06:46 AM
ro2207
Dec 4, 2014 06:18 PM
GigaMp3z
Feb 20, 2003 02:57 PM
