Pitting on block - Should I deck it?
Old Mar 17, 2011 | 10:46 PM
SweetZRag's Avatar
I've got about 80K miles on my rebuilt LT1. It was bored .030 over. I started getting coolant loss and when I pulled the heads, I found signs of a leak into the #7 cylinder. I had the heads checked for leaks. They are good and within spec for flatness.
I found pitting on the block deck surface near the coolant port nearest the rear of the block at the bottom. It is located about 1/8 in. from the cylinder. My question is will the new 1074 Felpro gasket seal this or should i have the block decked. I hate to go through another complete rebuilt with only 80K miles on this motor.
If I need to strip the block to get it decked, would you recommend all new bearing or just reuse them?
Here are some pictures of the pitting:
http://upmyphoto.com/image/59004/6c476d2
http://upmyphoto.com/image/59003/0069980
Old Mar 18, 2011 | 07:35 AM
bw_hunter's Avatar
Re: Pitting on block - Should I deck it?
It's hard to tell from the pictures so I'd recommend taking it to your local machinist for a 'read'
I also can't speak to the bearing without seeing them. I will share that I never reused bearings once the engine has run.....
Old Mar 18, 2011 | 08:20 AM
SweetZRag's Avatar
I have the engine out but I only have the heads off. It is still sitting on the K member and the trans is still attached. I am trying to avoid fully dissassembling the block if I don't have to but it looks like I will need to just take it to the machine shop for evaluation.
I know in a perfect world the deck should be perfect but I was hoping someone would tell me that the gasket would seal it. I know the pictures are a little blurry.
I'll get a better camera and post some clearer pictures. I appreciate the input.
Old Mar 19, 2011 | 09:08 AM
RUDEDOG's Avatar
I would go with new 1074's.
Old Mar 20, 2011 | 12:41 AM
97Z28Muscle's Avatar
I would roll the dice and not tear that bottom end down. I don't see why a new gasket and new head bolts wouldn't seal that little imperfection.
Old Mar 20, 2011 | 10:23 AM
SweetZRag's Avatar
Thanks guys. I did buy new 1074s. I am going to separate the transmission today and pull a few of the accessories off the front and take the engine with bottom end still installed to the machine shop for a look see. I have an extra car so I am not in a rush. I am just trying to avoid unnecessary work and expense.
If I do deck it, then I am trying to decide if I want to zero deck it which would entail having the intake machined also. Decicions, decisions
I hope to post more clear pictures tonight when my buddy brings his professional camera over.
93 RedBird
Nov 15, 2015 08:24 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
heus
Sep 8, 2015 12:01 PM
