coolant to the throttle body
Old Mar 17, 2011 | 01:03 PM
Z28allmine77's Avatar
I just noticed a coolant line just under the vacuum line on pass side of throttle body was penched at a 90 degree angle and spung alea that i spraying on the tps sensor and iac sensor plugs. my question is what are the coolant lines for and what symptoms would it cause not flowing properly
Old Mar 17, 2011 | 01:04 PM
Re: coolant to the throttle body
oh yea 1996 cherolet camaro z28 lt1
Old Mar 17, 2011 | 01:28 PM
Coolant flow through the TB is to keep the TB blades from freezing in very cold extended driving. Most people just eliminate it.
http://shbox.com/1/tb_bypass.jpg
Old Mar 17, 2011 | 09:48 PM
ok thank you so it would not hurt anything to cap them off even for a daily driver?
Old Mar 18, 2011 | 05:08 AM
Correct. Many of us in the cold north have removed the coolant from the throttle body, with no ill effects. In fact, dyno proven to pick up 6 HP:
http://www.ws6.com/mod-8.htm
Old Mar 19, 2011 | 08:59 PM
thanks i will do that
Old Mar 20, 2011 | 12:31 PM
OBE1 95Z28's Avatar
Most people bypass the TB, connecting the coolant lines "around the TB". You don't want to cap off the line running from the back of the heads as this "steam pipe" eliminates gas (steam) build-up in the heads. Do a search on throttle body bypass.
Potent77
Mar 16, 2022 12:13 AM
Peytons'z
May 6, 2021 09:25 AM
HectorM52
Jul 30, 2017 11:46 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
captcorvette
Mar 7, 2015 12:37 PM
