Piston rings for forced induction
Old Dec 31, 2020 | 10:42 PM
raroz28's Avatar
I couldn't find a great answer in all my searching, so I reached out to total seal for their options. They recommended two options.
PART# DESCRIPTION QTY PRICE EXTENSION
CS3690GP 35 4.030+5 1/16 1/16 3/16 8CYL 1 $461.33 $461.33 (https://www.jegs.com/i/Total-Seal/90...GP-35/10002/-1)
MS3690GP 35 4.030+5 1/16 1/16 3/16 8CYL 1 $532.70 $532.70 (https://www.summitracing.com/parts/tsr-ms3690-35)
As you can see, the cheaper option is $461, and the gapless more expensive option is $532. I thought that this was really high, but I want to ensure that I am using the appropriate piston ring. These appear to be steel.
Is this necessary, or would I be ok with a ductile iron plasma moly top ring? This ring here from Mahle is what I was planning on running, due to the cost of the Total seal rings.
https://www.summitracing.com/parts/mle-4035ms
I am anticipating around 600-650 rwhp with a forged 383 and D1SC.
Old Jan 8, 2021 | 12:25 PM
Pampered-Z's Avatar
Re: Piston rings for forced induction
I'm using Sealed power Hellfire rings. These are for forced induction.
Old Jan 9, 2021 | 02:00 PM
raroz28's Avatar
Got a part number?
Old Jan 10, 2021 | 12:38 PM
Pampered-Z's Avatar
Originally Posted by raroz28
Got a part number?
Sorry I don't. I'm 40 over/I have a 385 so it would be a different part#
Old Jan 10, 2021 | 02:58 PM
raroz28's Avatar
Yeah, I just wanted to see what type of material you had. The only hellfire rings on Summit are Iron, which I would imagine aren't as good as the ductile iron with plasma moly from Mahle.
I could be overthinking it, but I want to ensure the rings I get will hold up, as I do not want for something like that to fail. If I must spend the $500, I will, but I don't want to if I do not need to.
sc00ter
Aug 15, 2013 12:15 AM
Dave88LX
Mar 21, 2004 09:11 PM
Fatsix
Nov 6, 2003 06:56 PM
99huggerorangeZ
Advanced Tech
18
Feb 1, 2003 04:56 PM
99huggerorangeZ
Advanced Tech
Jan 27, 2003 10:21 PM
