total seal rings
Old Jan 26, 2003 | 06:57 PM
99huggerorangeZ's Avatar
Question total seal rings
i am building a 383 with a 4" bore and a 3.75" stroke with 6" rods
whe pistons i am using are JE Part Number 178676 but i am wondering what rings to use?
the ring widths are 1/16, 1/16, 3/16
when i look for rings do i need rings that have a STD overbore?
i cant find any total seal TS1 rings with a STD overbore in jegs and summit all they have is .005
do i have to use .005 rings with my 4"bore
Old Jan 26, 2003 | 07:12 PM
camcojb's Avatar
If your bore is still standard and will not be bored .030" over, then you need the .005 over rings. They are a file-to-fit ring set for standard bore. This means that you must file the ends to get the correct gap, you cannot just install them. Advantage is you get the exact ring gap you want.
I wouldn't recommend Total Seal rings on any street car except maybe to an enemy. EVERY set I've tried has used oil....every one.
These were all professionally machined blocks with Total Seals recommended block prep. I have spoke with MANY people who've had the same results. You'll find a few that think they work great, but far fewer than those who dislike them for their oiling problems.
I use Speed Pro plasma moly file-fit rings in everything I build now. They seat immediately and do not use oil.
Jody
Old Jan 26, 2003 | 08:14 PM
Mindgame's Avatar
A big amen on the Speed Pro recommendation. Every racer I know has had, or knows someone who's had problems with the TS gapless ring sets. A well machined and blueprinted engine will have low leakdown figures anyways... not the tell-all of engine performance either way.
You technically have a 377 with the standard bore. I'd go with a file fit SP ring-set but it's your money.
-Mindgame
Old Jan 26, 2003 | 08:52 PM
brand-x's Avatar
I ran totalseal rings in my last engine...the coating on the face of the ring flaked off and caused damage to the cylinder bore...you should have tried a leak down test on my engine after the rings failed....good bye ts, hello speedpro.
Old Jan 26, 2003 | 09:57 PM
Blownbird355's Avatar
rings
I have them on my present blower engine no oiling probs, but have heard strange stories bout them actually causing blowby and dont think theyre worth the added exspense.
Old Jan 26, 2003 | 09:58 PM
Question
JE offers a rings set with the pistons i am purchasing
would it be a good ideal to purchase rings from the piston manufacturer?
Old Jan 26, 2003 | 10:56 PM
96z's Avatar
96z
That or atleast ask the piston manufacture what rings they reccommend.
Old Jan 27, 2003 | 06:30 AM
rskrause's Avatar
Moderator
I have done it this way for years. JE is an excellent source of both rings and pistons.
Rich Krause
Old Jan 27, 2003 | 10:21 PM
Question
does JE use the same technology for their rings as total seal with a gapless 2nd ring or do thye use the OEM style rings?
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
colts0455
Sep 27, 2015 01:07 PM
mmf_1013
Sep 12, 2015 08:56 PM
blaze309
Sep 8, 2015 05:27 PM
