Piston/Clearance question
Old Apr 16, 2008 | 12:33 PM
Stroked96Bowtie's Avatar
Curious as Im looking at a set of heads, is a 2cc valve relief common amoung aftermarket pistons? These are a flat top piston that these heads are working on now. The heads have 2.10/1.60 valves.
Trying to understand the likely hood of them clearing my 383 bottom end, only issue is I dont exactly know the details on my pistons.
Old Apr 16, 2008 | 12:53 PM
WS Sick's Avatar
Given a stock deck height of 9.025 inches and 55 cc heads , you'll have compression right around 12.5 :1 on a 383. but a flat top with 2 small valve reliefs is pretty common with that size. I'm using a 12cc dish and a "0" decked block with a .040 gasket on my set-up(383). It runs on 91 fine.
Old Apr 16, 2008 | 12:54 PM
WS Sick's Avatar
Oh forgot to add, as far as valve clearance, you just have to mock-up and check it with clay ( I like blue playdoe)
Old Apr 16, 2008 | 02:44 PM
mdacton's Avatar
Piston to valve clearance is all in the cam......
Old Apr 17, 2008 | 11:28 AM
WS Sick's Avatar
so when the valve hits the piston with .600 lift.....
Why not just mock it up and see if your reliefs need enlarged?
Old Apr 17, 2008 | 12:09 PM
mdacton's Avatar
well thats what you do. If its close.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
