Pins #15 & #31 on "Black" connector to PCM
Old Dec 5, 2006 | 07:59 AM
19z28camaro02's Avatar
These are the Battery Feed Wires for the PCM, Where do they get their power from?
Old Dec 5, 2006 | 08:04 AM
cajun94's Avatar
Originally Posted by shoebox
PCM BAT fuse. I meant to say previously, that the part of the PCM that powers up when you turn the key is via the ignition switch. The PCM BAT fuse sends power to the PCM at al times. Feeds through the orange wire in cavity C of connector C210 under the RH kick panel.
He tells you right here....
Old Dec 5, 2006 | 08:06 AM
sbs's Avatar
sbs
The wiring diagram for my vette says they come from "ECM fuse 1 (20A)"
Old Dec 5, 2006 | 08:08 AM
the fuses in the block test good, but i dont have power at the PCM
Old Dec 5, 2006 | 08:10 AM
sbs's Avatar
sbs
Was there power coming into that fuse?
If not, then you have a wiring problem between the battery and fuse.
If yes, and the fuse is good, then you have a wiring problem between the fuse and the PCM.
Old Dec 5, 2006 | 08:12 AM
All of my fuses are good, i put the test light to the ground and then onto the fuse, and the light lights up. I go to the PCM wires to do this and the light does not illuminate. WTH?
Old Dec 5, 2006 | 08:14 AM
cajun94's Avatar
I know this sounds dumb but do you have key on?
Old Dec 5, 2006 | 08:15 AM
sbs's Avatar
sbs
You did check that the fuse is not blown, right?
If so, then you might want to read what that guy said in post #5.
Old Dec 5, 2006 | 08:16 AM
sbs's Avatar
sbs
This is not keyed power.
Check out his other thread on the same subject:
http://web.camaross.com/forums/showthread.php?t=488443
Old Dec 5, 2006 | 08:21 AM
yes, but click here and look at pins 15 and 31, they are a constant hot.
Old Dec 5, 2006 | 10:56 AM
Not sure why you started another whole thread on this subject. I told you where the power came from in the other thread (reiterated by quote in post #2 of this thread). You don't seem to want to listen.
Old Dec 7, 2006 | 12:14 PM
You now have 4 threads on the lack of power to the PCM and 3 threads on the fuel pump schematic.
NO MORE DUPLICATE (or triplicate or quadrupicate) THREADS!
You have been warned.
techstar
Aug 6, 2015 11:20 AM
88IROC_Z
Jul 22, 2015 11:38 PM
whitehooptie
Jul 22, 2015 10:25 PM
gelbza
Jul 12, 2015 08:10 AM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
