(Pics)What is this, and whats it supposed to be hooked up to??
Old Jan 30, 2008 | 11:16 AM
96supersport's Avatar
Its on the drivers side, just below the abs brick
heres some pics, is it supposed to be hooked up or what?
Old Jan 30, 2008 | 11:18 AM
ssbowtie1's Avatar
That looks like the vacuum line that goes into the intake manifold near the PCV valve. Does it go that far or does it look like it belongs in the area where it is.
Old Jan 30, 2008 | 11:19 AM
Originally Posted by ssbowtie1
That looks like the vacuum line that goes into the intake manifold near the PCV valve. Could be wrong though.
theres no way it would reach
it can only move about 3 inches in either direction.
im stumped i need to know where it goes, ive looked on shoebox for diagrams and everything
Old Jan 30, 2008 | 11:30 AM
madhatter's Avatar
Air pump.
Old Jan 30, 2008 | 12:01 PM
ss.slp.ls1's Avatar
I would like to see that diagram as well. I may or may not have this hooked up correctly on my car. I know in my car there is some type of selenoid near my coil. So I believe that vacuum hose is some how connected to that selenoid, the air pump, and the intake manifold, but i don't know in what configuration. Good luck, keep us posted.
Old Jan 30, 2008 | 12:04 PM
MEAN LT1's Avatar
Originally Posted by madhatter
Air pump.
Agreed.
Old Jan 30, 2008 | 12:54 PM
hmm, so it hooks up to the air pump? or is it supposed to just chill there?
if it does hook up to the pump that might explain my ses secondary air injection system code
Old Jan 30, 2008 | 12:57 PM
Looks like the connection to the AIR pump bleed valve.
http://shbox.com/1/air_pump_recall.jpg
Old Jan 30, 2008 | 01:01 PM
mnws6's Avatar
http://shbox.com/1/air_pump_recall.jpg the first picture should help
Old Jan 30, 2008 | 01:02 PM
So is it supposed to not be hooked up?
do i just leave it there? or where does it hook up too
Old Jan 30, 2008 | 01:25 PM
Umm, the pictures says it goes to the bleed valve. What am I missing?
Old Jan 30, 2008 | 01:28 PM
upon further inspection the bleed valve only has 2 male connectors which are both being used
on of the connections runs right to that thing that hangs down.
it cant connect to the bleed valve, since it already is.
Old Jan 30, 2008 | 01:42 PM
You got me, then.
Old Jan 30, 2008 | 01:51 PM
ss.slp.ls1's Avatar
From the picture it appears that the little connector, at the end of the vacuum hose that is just hanging there, that kinda looks like an "F" is not supposed to be there. It should be hooked up to your intake manifold. With one line going to the egr solenoid and one line going to the vacuum solenoid near the air pump. Hope I'm right and that helps.
P.S. I cannot tell you how helpful shbox.com has been for me, thanks man.
Old Jan 30, 2008 | 01:53 PM
well it cant reach that far
im stumped, could someone take a picture of that area on there 96 97 car so i can compare?
