Pickup tubes: 5/8" versus 3/4"
Old Oct 10, 2007 | 09:24 PM
marshall93z's Avatar
Is 3/4" necessary? Car is a 93 and it came with the 5/8"...just curious. Engine isn't gonna be a screaming 7k rpm monster or anything, just a cam only gm847.
And for the record, there are WAY too many different oil pumps to choose from!
Old Oct 11, 2007 | 02:38 PM
I'm talking about the oil pump pickup, just in case no one knows what I'm talking about!
Old Oct 11, 2007 | 02:41 PM
Ok4thGen's Avatar
Let me look around and see what i can find for you on it.
Did you already buy the cam?
For what your wanting a GM847 is a bad choice for you, that cam loves higher rpm and needs to breath threw a good set of heads, theres much better options for you that will still allow some actual low end power still.
Old Oct 11, 2007 | 02:51 PM
Everything is already purchased. Compression was built around the cam to get the DCR in check.
3600 stall should take care of "low end power".
Old Oct 11, 2007 | 03:09 PM
bdc95ta's Avatar
What pump, pan?
Old Oct 11, 2007 | 03:14 PM
Stock pan. And the pump is what I'm wondering about. Should I get one with 3/4", or 5/8" hole?
Old Oct 11, 2007 | 06:56 PM
There was a recent thread with pump recommendations. I'd go with the 3/4".
Old Oct 11, 2007 | 11:30 PM
Ok, thanks!
Is the M155 worth a crap?
Old Oct 17, 2007 | 07:41 PM
After a TON of reading, it seems that Melling makes almost everyone's housing for their pumps. Which would mean they ALL suck!
Can I order a new one and put the parts in my stock housing?
Old Oct 17, 2007 | 07:48 PM
FASTFATBOY's Avatar
I have a Melling Select pump in my car with the 5/8 pickup, works good.
David
Old Oct 17, 2007 | 07:58 PM
Wow, I'm surprised you used a 5/8"
Where did you get yours and how much?
Old Oct 17, 2007 | 08:02 PM
FASTFATBOY's Avatar
Summit Racing, was like $55 I think, pickup came from Canton to match the pan.
David
Old Oct 17, 2007 | 08:04 PM
Cool.
Do the Melling Selects not have the thin mounting point like the others?
Old Oct 17, 2007 | 09:29 PM
FASTFATBOY's Avatar
Cool.
Much nicer pump, hardened internals etc.
I lied my pickup IS 3/4. Mine was a MEL 10555 or something like that.
David
Old Oct 18, 2007 | 10:12 AM
cehan's Avatar
I recently got a Melling MEL 10550 Select series pump that I am going to use to replace the MEL M55HV that I am currently using. It has a 5/8" pickup.
