pic of moroso cai installed?
Old Aug 18, 2007 | 09:53 PM
limige's Avatar
just bought a used one, went to install my new trick flow elbow and mock up the cai and i don't see how the cai is supposed to clear the radiator and make it to the hole down below?
Old Aug 18, 2007 | 10:09 PM
94_PatriotRed_Z's Avatar
I can get you some tomorrow, when it is light out. If you still need them
Old Aug 19, 2007 | 11:18 AM
JP95ZM6's Avatar
Mine touches at the radiator (in the depression on the bottom of the CAI) and also hits the hood a little. If yours won't fit, you can gently heat the CAI and reshape it to clear the radiator. You can use a 500W worklight a couple feet away, shining through a hole in something that won't burn to control where it applies heat. Or a heat gun on low. Mine is a tight fit, but works:
Old Aug 19, 2007 | 11:42 AM
CamaroUK's Avatar
The only issue I had installing mine was that I had to cut a couple of centimetres off of the MAF side of the CAI as I found it was too long.
Old Aug 19, 2007 | 12:08 PM
limige's Avatar
yeah, i got shorted that peice next to the maf so i'll have to go looking for a sleeve shortly.
thanks, i'll take another look at mine, i thought it was supposed to sit a bit lower..
Old Aug 19, 2007 | 06:07 PM
limige's Avatar
figured it out, but the filter is interferring with the inner fender..
thenewkid
Nov 27, 2014 09:41 AM
ScottZ
Mar 3, 2004 01:34 PM
TheV6Bird
Aug 27, 2002 10:38 PM
jim88iroc305
Aug 13, 2002 09:24 PM
kurob25
Aug 5, 2002 08:03 PM
