pic of carbed 4th gen.
Old May 26, 2003 | 10:16 PM
BlakCamZ28's Avatar
I am lookin for a picture of a carbed 4th gen....race car street car or whatever just so I can show someone how much you have to cut the cowl. Thanks
Old May 26, 2003 | 10:19 PM
93formula's Avatar
i dont think you have to, gm made a lt1 carb intake.
Old May 26, 2003 | 11:27 PM
bob94z28's Avatar
From: Council Bluffs, IA Might as well be Omaha though!!!
those are more for if you want to drop a carbed lt1 into a non 4th gen. car.
Old May 27, 2003 | 07:43 AM
johnpsz's Avatar
Here are some pics here of a similar setup, not carb but look.
Joe Overton If that link doesn't work go to www.fbodycentral.com then click on the link to Joe Overton
Old May 27, 2003 | 08:58 AM
Brent94Z's Avatar
Super Moderator
I've got a Sony Image Station album with probably 15 or 20 pics of a carb'd 502 ci 4th gen. If interested, they start on the first page of The Gathering 6 index then go from there.
http://www.imagestation.com/member/i...Brent94Z&c=201
Old May 27, 2003 | 09:19 PM
DWoodAudio's Avatar
admittedly this article goes a bit overboard on information, but if you're patient enough to read thru it you can see what putting a carb motor in a 4th gen F-car involves. Also a lot of interesting information about building a car from the ground up
http://members.aol.com/weissracin/asbuild.htm
Old May 27, 2003 | 10:05 PM
grendal's Avatar
I'm pretty sure you could cut out a lot LESS than that if you went with a low profile air cleaner or a remote air cleaner (similar to the Vortec truck engines). No need to have that huge air cleaner shoved up under there with it...
-Michael
Old May 27, 2003 | 10:58 PM
DWoodAudio's Avatar
probably true but that car was built to a specific set of class rules that dictated engine, manifold, carb, hood, etc......so they were pretty much locked into making it work as it was.
cmsmith
Mar 16, 2015 02:34 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
