People w/ Solid Roller setups>>>>>>
Old Jan 10, 2007 | 12:43 PM
ProchargedLT1's Avatar
Please list your valvetrain setup, lifters,pushrods, springs, rockers,etc,etc.
Thank you
L8tr
Old Jan 10, 2007 | 12:51 PM
Projectz28's Avatar
Moderator
Cam motion solid roller 263/270. TFS heads with Ferra 2.08/1.60 valves, +.100" lenghth. Dont know the spring manufacturer actually. I had the heads built by TEA and they list them as TF springs which I know for a fact they dont actually make them. anyway they are 1.550 OD springs, set up to 1.950" height, with comp +.050" ti retainers and Comp .080 lash caps. 225LBS on the seat and I think it was 580lbs open (i cant remember the exact open pressure but thats close to it) Running Jesel Sportsman Series Shaft mount rockers, 1.60 ration on I and E. Manton series 5, 3/8" pushrods (on order now). Valve lift is .686" Intake and .674" exhaust with the 1.6 rocker. and I picked up a set of barely used com endurex lifters off of here.
not running yet but should be soon.
Old Jan 10, 2007 | 01:49 PM
95Bird's Avatar
Old setup, cam motion solid roller, 255/263 657/628 on 110 ls. LT1 heads with 2.0.1.57 + .100 valves. comp endure-x lifters, comp 1.52 roller lifters, isky springs..can't remember the spring number. Changed to lt4 heads with 2.05, 1.57 valves and kept everything the same other than the head change for a little while then changed to Jesel sportsman shaft mounts with 1.6 on the int/exh.
New setup..everything in valvetrain is the same except got a bigger solid roller that futral motorsports speced out and went to crane 999 springs.
Old Jan 10, 2007 | 02:59 PM
CC cam, Crower Cutaway Severe-Duty lifters, CC 5/16" Hi-Tech pushrods, CC 1.6-I/1.55-E Pro-Magnum rockers, Manley guideplates, PSI valve springs, Manley titanium retainers.
Old Jan 10, 2007 | 04:51 PM
95Zedder's Avatar
Crane Small Base Circle Custom Cam, Comp Cams Endure-x Lifters, Comp Cams Custom Hi-Tech Pushrods, 2.100/1.600 +.250/+.250 Manley Pro Flow Valves, Crane Roller Springs 224/717lbs pressure, Crane Titanium Retainers, Jesel Sportsman Shaft Rockers 1.6/1.6
Old Jan 10, 2007 | 08:31 PM
Ram Air 383's Avatar
Comp Cams 240/598 lbs springs, titanium retainers, endure-x lifters, hi-tech pushrods, hi-tech 1.6 stainless rockers on 7/16" studs, Ferrea stainless 2.08/1.60 +.100" valves.
Old Jan 10, 2007 | 09:12 PM
Dave69Z's Avatar
Isky Tool Springs, Isky Redzone Aluminum Top Lifters, Isky Rev Kit and some T&D shaft mounts once I can save up for them.
Dave
Old Jan 10, 2007 | 09:42 PM
SStrokerAce's Avatar
Pretty standard setup I would do
The most important part Springs:
Isky Tool Room "Gold Stripe" Springs (99X5 Series)
Comp 26000 Pro PAC Series (PAC Made these Previously)
Either with a Nice Ti Retainer or better off some trick Steel Lightweight Retianers (This are usually mucho bucks but never need replacement where Ti stuff will)
Lifters:
Comp EndureX
Isky Red Zone
Pushrods:
3/8th at the smallest
Comp Hi Tech
Trend
Manton
Smith Brothers
Rockers:
Jesel, T&D or DRE Shaft Mounts
You can also get by with stud mount rockers with a stud girdle but I would make sure you have top notch parts in this setup to pull it off.
Cam: Whatever fits, Billet Core Only due to the spring pressures.
Bret
Old Jan 10, 2007 | 10:00 PM
reamo04's Avatar
bret, thanks for that list
would LE3 LT1 heads flow fine for a SR setup, or would u recommend AFRs or something? I know we have previously talked about this, but I forgot.
Old Jan 10, 2007 | 10:02 PM
They will work great Clint is actually running a setup like that this year... most times on a LE SR setup that's the type of parts being used.
Bret
Old Jan 11, 2007 | 02:03 PM
Thanks everyone!
I noticed some people have +.100" vavles, does this help with getting a better install height?
Thanks everyone again!
L8tr
Old Jan 11, 2007 | 02:50 PM
Procharged.... yep.
Old Jan 12, 2007 | 04:26 PM
I sent Comp Cams a SR cam request and this is what they e-mailed back.
252/258 .630/.630 106lsa
part no. 12-900-9
Intake master - 4006s
Exhaust master - 4007s
Valve springs 954-16
Old Jan 13, 2007 | 07:02 PM
Turbo6's Avatar
I'm running a Comp billet 25x/26x .660/.660 lift cam with 1.6 T&D shaft mounts, Isky Tool room springs, super 7deg locks, titanium retainers, comp EndureX lifters 3/8 comp pushrods. I had the pacalloy's and had a nasty harmonic at 6500rpm.
Old Jan 13, 2007 | 08:34 PM
cdb95z28's Avatar
I`m probably runnin` the smallest SR around ( I can hear Bret laughing now ) here`s my stuff anyway......
Comp Xtreme 230/236/112, 1.6/1.5 7/16" Pro Mags, ARP studs/ PermaLocks, Ferrea 2.02/1.60 6000 Series valves (+.050" length), Comp 977 springs (155lbs seat), titanium retainers, 10* Super Locks, 888 Endurex lifters, Hi-Tech 5/16" +.200" pushrods, GM ED LT4 timing set w/ Cloyes oversize crank gear, AFR 190cc heads, everything fits under Proform black crinkle centerbolt valve covers.
-Beehives$$, shaft mount rockers$$ in the future
