PCV tube comming from passenger side valvecover
Old Jan 25, 2004 | 04:23 PM
anasazi's Avatar
is this tube suppose to be under vacuum on the valvecover side? i thought it was the opposite and thats why oil gets into the throttle body?
Old Jan 25, 2004 | 04:31 PM
Re: PCV tube comming from passenger side valvecover
Might want to try a "search"... I know I have explained this maybe 20 times....
In a healthy engine, there is no vacuum in the line. It flows filtered/MAF measured air from in front of the TB blades, to the valve cover, where it is pulled through the engine by the PCV valve to eliminate harmful crankcase vapors. If for some reason the PCV valve can't handle the volume of crankcase vapor... the valve is plugged, or you are getting excessive ring blowby, pressure will build in the crankcase and force the vapors back through the valve cover/line to the TB, through the top of the TB, and they get sucked in through the throttle blades.
Old Jan 25, 2004 | 04:40 PM
anasazi's Avatar
ohhhhhh
ok
i've read it a hundred times, just never really got it till now i guess
blown94
May 3, 2015 12:48 AM
Jul 4, 2005 05:00 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
blue89iroc
Jul 26, 2002 04:56 PM
Wilson
Jul 21, 2002 05:08 PM
