pcv question...
Old Jul 5, 2007 | 11:06 AM
96LT1TX's Avatar
pcv question...
I had a high RPM miss on the last run of the day last time I was at the track and someone told me to check my PCV system. I looked at the "line from the throttle body to the passenger side valve cover is the line that supplies fresh air to the crankcase" and the part that goes into the valve cover seems to be somewhat blocked... is this a problem? The line also seems cracked a little and is very used/abused. Could this cause a high rpm miss? This miss only happened once in 2nd gear and once in 3rd gear both at near 5500rpms... never had a high rpm miss until that one run, mph was like 1 mph lower than previous runs.
Any help appreciated.
drt
Sep 27, 2015 04:39 PM
surreybrad
Aug 10, 2015 09:34 AM
OH NO AN LT1
May 6, 2003 10:15 PM
asianice25
Apr 2, 2003 11:42 AM
got_hp?
Mar 15, 2003 11:11 PM
