PCV Catch Can
Old Jan 14, 2009 | 05:21 PM
95Blackhawk's Avatar
PCV Catch Can
OK, would I be going down the right road by ducting from PCV to a catch can?
The intent is to eliminate the issues with excessive oil getting into my intake because of my constant high RPM road racing.
I am intending to also plug the breather from TB to the valve cover. I would then recalibrate the MAF to compensate.
Is this the correct route to go?
Thanks all!
Old Jan 14, 2009 | 06:09 PM
sn8ke eatr's Avatar
well im not sure what kinda can your talking about ( got pics/ brand/ pn?) but i have a nice anodized red one where theres both an inlet and an outlet,
the inlet is the line coming from the valve cover, the oily air goes in and theres like a metal mesh that catches all the oil, then the outlet goes into that line that goes to the T.B you were talking about.
on the bottom of the can theres a pepcock to drain all the oil that has collected in the container
hope that helps some,
Old Jan 14, 2009 | 06:36 PM
You need to do it with the method sn8ke eatr has. There will be no effect on the computer.
Old Jan 14, 2009 | 07:05 PM
Yes it does. What info can you share on yours? Do I need to worry about oil from the PCV side also? sounds like you are accomodating the TB breather only? Is this the only source of oil generally?
Old Jan 14, 2009 | 09:44 PM
An epiphany:
I don't have to pass emissions. What is wrong with just plugging the TB breather and having the valve cover vent with a filter? Further, just have the PCV vent to the atmosphere through another filter? (of course plugging the inlet to the manifold from the PCV)
This would eliminate the vacuum issues.
Old Jan 14, 2009 | 09:59 PM
...and the best crankcase evacuation method.
Old Jan 15, 2009 | 05:28 AM
You need air flow through the crankcase to pull the water (and other) vapor out. Even the crudest engines of the 1950's had a "draft tube" to help evacuate the crankcase.
Old Jan 16, 2009 | 04:23 PM
sn8ke eatr's Avatar
oil from the pcv side is a different story. you could either run a line and with a fitting direct it to the same catch can, or run another one on the other side of the engine
open breathers are an option but i know when i had one oil used to get all over my valve cover, especially at long duration high rpm when the whole evacuation system is needed most
drt
Sep 27, 2015 04:39 PM
95craz28
11
Sep 12, 2015 07:47 AM
RX Speed Works
Sep 11, 2015 03:31 PM
surreybrad
Aug 10, 2015 09:34 AM
RX Speed Works
Jul 24, 2015 02:25 PM
