Pcv
Old Jun 20, 2006 | 04:35 PM
TransAmGT94's Avatar
Pcv
When i did a motor swap i bought the egr block off kit which came with the egr system block off and the pcv valve block off. When i started it up i smokes from the valve covers. do i have to run a pcv valve or can i leave it blocked off and vent a different way? it is killing the car at idle when i run it. need help plz. Thanks
chris
Old Jun 20, 2006 | 04:43 PM
Re: Pcv
sorry i was looking at the wrong thing the kit blocked all egr stuff so why am i not venting?
Old Jun 20, 2006 | 05:06 PM
mebanditws6's Avatar
Re: Pcv
From you what you told me on the phone, I bet it could simply be a stuck PCV valve. Try that first before ditching the breathers. It shouldn't hurt having extra means of venting off crankcase pressure. Ben's 454SS bolt on smog motor did fine with 2 breathers.
Jason
Old Jun 20, 2006 | 05:28 PM
Re: Pcv
Do you still have the vent line from the throttle body to the valve cover attached and functioning? Do you have the PCV valve in place on the drivers side of the intake, and the U-shaped tube connected to the vacuum port?
Old Jun 20, 2006 | 07:33 PM
Re: Pcv
Yes to all the above its getting another pcv maybe that will fix it. The PCV sticks a little. Any other ideas?
Old Jun 20, 2006 | 08:36 PM
Re: Pcv
car idles like it is missfiring but seams to clear up when i pull the breather out and let the fumes vent from the valve covers. Maybe it is killing it self.
Old Jun 21, 2006 | 09:55 AM
Re: Pcv
So you have a breather AND the line from the TB to the valve cover installed? Why would the breather not let the fumes vent? That's the purpose of an open breather. Confusing.
Old Jun 21, 2006 | 06:34 PM
Re: Pcv
Ok the second pcv fixed the problem now im have a whole new problem with the alt. im going to start a new thread for it
drt
Sep 27, 2015 04:39 PM
surreybrad
Aug 10, 2015 09:34 AM
mineralwater
Oct 17, 2003 05:34 PM
asianice25
Apr 2, 2003 11:42 AM
got_hp?
Mar 15, 2003 11:11 PM
