Which PCMs are interchangable???
Old Mar 5, 2007 | 07:32 PM
ZONES89RS's Avatar
I bought this 95 camaro Z28, couldnt figgure out why it wont get fire, new coil, ignition module was good, but nothing, i took the car to a shop i trust today, they called and said that the computer part number or somthing doesnt match, none of the ones i have do they said, i gave them 2 more when i dropped it off, i thought they were all interchangable, i told him this and that to make sure he did not run the 95 model OBD II connection poer with OBD II and to run it with OBD I, he has not called back yet, any info is greatly appreciated guys, i need this thing on the road ASAP, the car was sitting for a year before i bought it, replaced the opti and waterpump.
One of the extra PCMs are from a 95 SS and the other from a vette, imnot sure what year the vette PCM is from.
Old Mar 5, 2007 | 07:37 PM
94-95 PCMs should interchange and 96-97s should.
Old Mar 5, 2007 | 08:29 PM
ZONES89RS's Avatar
www.shbox.com right? madz28 recommended you for looking a wiring and what not, so 96 and 97 should also work???
Old Mar 5, 2007 | 08:43 PM
OBE1 95Z28's Avatar
96 - 97 are OBDII, you need an OBDI PCM that's not batch fire (93), so as Shoebox stated above, 94 - 95 PCM
Old Mar 5, 2007 | 10:23 PM
That's me (notice my sig).
Maybe I should have clarified. 94-95s interchange with each other. 96-97s interchange with each other. 94-95s (OBD-I) are not the same computer as 96-97s (OBD-II). But, you can convert within these years from one OBD type to the other with minor modifications.
Old Mar 6, 2007 | 11:40 AM
ZONES89RS's Avatar
Ok, will they interchange at all and hook up??? I have 3 of them, i know one supposedly had a LT4 knock module, which of course tells me it was a 96 model vette PCM right?
Old Mar 6, 2007 | 11:51 AM
LT1 Corvette, B-body and F-body use the same computers. F-body 94-97 computers have the same pinned connectors on the back, so any 94-97 engine harness will plug in. Anyone can put an LT4 KM in a computer, so it really means nothing.
Old Mar 6, 2007 | 06:45 PM
ZONES89RS's Avatar
Ok i found out that it will run with any PCM, if it is the OBD II on a OBD I car it will run in LIMP HOME MODE and what not, turned out that the pig tail wat missing the clip to connect to the OPTI, thanx for the help. The PCM will not read when a scanner is hooked up, any ideas? i know i am not the first to have this problem.
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
