PCMfor less didnt fix my problem
Old Jul 31, 2004 | 02:09 AM
Hardee46360's Avatar
Ok, Pcm helped Idle a little, but car still has low oil pressure! New ported heads, LT4 -hotcam, New wires, BBK shortys, all installed 3 weeks ago, need serious help!!!!! Loud ticking noise under the hood now. WTF!!!!! GOD, I just want my car back to running normal!!!!!!
Old Jul 31, 2004 | 05:48 AM
Spinner's Avatar
Re: PCMfor less didnt fix my problem
Looks like you did the !rod bearing mod unfortunately
Old Jul 31, 2004 | 06:22 AM
smoknta's Avatar
How could the tune affect the oil pressure? That doesnt make any sense. The ticking could be a valve out of lash or something like a bearing going out.
Old Jul 31, 2004 | 07:30 AM
ibanez6rg's Avatar
Maybe because PCM For Less had no way of fixing your problem?
Old Jul 31, 2004 | 07:55 AM
ninetythreez's Avatar
When you installed the cam, did it engage the oil pump drive gear properly?
Check valve adjustment.
Good luck.
Old Jul 31, 2004 | 01:00 PM
truedualws6's Avatar
The tune and your problem are not related. Do a search on the topic
"spun bearing after cam swap".
MattFick
Feb 15, 2015 10:16 PM
Alex Barnes
Jan 24, 2015 10:21 PM
siguy
Nov 27, 2014 10:07 AM
DougJ
Aug 29, 2002 12:51 AM
slothgrant
Aug 22, 2002 03:01 PM
