PCM qs
Old Dec 8, 2003 | 06:39 PM
Supermanx500's Avatar
PCM qs
I am going to be installing an lt4 knock module on my pcmforless tunned pcm. If I unplug the computer to install the lt4 km, will it reset the pcm to stock program?
Old Dec 8, 2003 | 06:46 PM
gb95zconv's Avatar
no.....your blm cells will reset but the pcm will relearn in a short time....program will not change.
Old Dec 8, 2003 | 07:03 PM
blm? sorry not sure what that means?
So all of my programing for pcmforless will be there but the knock sensor will reset. right?
I just want to make sure, I just don't want to mess something up because of a small mistake.
Old Dec 9, 2003 | 06:16 PM
gb95zconv's Avatar
youll be fine.
Old Dec 9, 2003 | 06:32 PM
1982z28with18s's Avatar
You don't actually have to unplug to PCM. You can just remove the two bolts holding the bracket in and then pull the PCM up and then you can remove the KM from there without unplugging the PCM. Just make sure to disconnect the battery before doing it.
Old Dec 10, 2003 | 08:38 PM
thanks
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
