pcm problems
Old Aug 19, 2013 | 06:37 PM
impidemic's Avatar
pcm problems
my 95 impala ss will run but can not connect with my computer tried to connect but get a no respones to pcm checked all fuses and changed computers and cable and still not working any help will be good. car is running good just need to change program for gears and stall.
If you have any information please e-mail me at impidemic@gmail.com
thanks in advance
Old Aug 19, 2013 | 07:50 PM
timnfxr's Avatar
Re: pcm problems
I'm not familar with the Impala. Does it have a 16 pin OBD connector? Does pin 16 have +12v? On the Z28 it's fused by the cigarette lighter fuse.
I'm using the ALDL Diag 16 pin cable (OBDI), and had a "No Connect" problem, which turned out to be that fuse. It powers the serial converter circuit built into the cable.
DirtyDaveW
Dec 1, 2016 05:37 PM
Scottyboy
Feb 11, 2015 10:28 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
97SSdude
Dec 31, 2014 07:43 PM
JSK333
Sep 9, 2002 10:33 PM
