PCM numbers?
PCM numbers?
I took out my computer tonite and on the top i found some numbers on a sticker. The previous owner had the car programmed by Ed Wright and it looks like Ed put this on. I was just wondering what these numbers mean.
396"/24lb/242-254cam/11.7-1
7500/1000/160/3.73/85mm
"Starr-396.BIN"/11-12-01
I know some of the info but anymore info on these numbers would be greatly appreciated. Thanks
I would assume put there by Ed.
My take:
396 cubes
24 lb injectors
242-254 cam, duh
11.7 compression ratio
7500 rpm rev limiter ?
1000 rpm idle ?
160° thermostat
3.73 gears
85 mm [edit] MAF
Starr-396.BIN = file name
11-12-01 = date of service
You could always call/email Ed and have him look it up for any details.
My take:
396 cubes
24 lb injectors
242-254 cam, duh
1000 rpm idle ?
160° thermostat
3.73 gears
85 mm [edit] MAF
F'n1996Z28SS
Aug 23, 2023 11:19 PM
carguy0119
Apr 11, 2016 11:11 PM
cmsmith
Apr 1, 2015 09:29 PM
