PCM for less options....
Old Sep 3, 2003 | 12:10 AM
S.J.S.'s Avatar
Got a 97ZA4 that I'm buildin a 383 for. Gonna get the PCM for less OBD1 Conversion.
This is what I'm runnin....
LT4 Hot Cam
1.6 rockers
SLP headers
52mm TB
Port and Polished heads
2600 stall with shift kit and Beast plate
30# injectors
There are a lot of options on the order form ....... I was wondering what I should get. I need some info. Like...
1. Do I want power programming? Yes I do
2. Do I want the top speed limiter removed? I dont think I have one already took it 155.
3. Do I want firmer shifts? Got a shift kit already????
4. Do I want the CAGS (skipshift) removed? I got a shift kit in the tranny....Don't know.
5. Do I want the air pump disabled? No clue
6. EGR removed? Still have it
7. VATS removed? What the hell is that
HELP ME OUT GUYS PLEASE. THANKS
Old Sep 3, 2003 | 12:37 AM
AndyB's Avatar
1. yes
2. Sure why not
3. If you want hard shifts select this option. But if this is a daily driver and the tranny has a shift kit in it already select no to this option unless you like rock hard shifts.
4. CAGS are for M6 cars only
5. If you have cats and the pump still works keep it. No cats = no need for air pump.
6. Keep it for now. You can block it off later if you need to
7. Vats. Keep it.
Old Sep 3, 2003 | 11:08 AM
S.J.S.'s Avatar
thanks.......that right all? Go with Andy's suggestions?/?????
Old Sep 3, 2003 | 11:13 AM
madwolf's Avatar
A 97 car has a limiter at 160 MPH, however, the Z-rated 94-95 programs (which are used by default by tuners) are limited to 255 MPH, so you really shouldn't worry about that.
I wouldn't add more firmness with a shift kit. Everything else looks good.
Old Sep 3, 2003 | 12:09 PM
Hyperspeed97z28's Avatar
97 cars 155. hmmm, I dont remember if I had you (Ion) remove that...
Old Sep 3, 2003 | 12:10 PM
madwolf's Avatar
Keith,
not sure if you asked me, but I'm pretty sure I set it to 255 on yours.
Old Sep 3, 2003 | 12:12 PM
Originally posted by madwolf
Keith,
Thanks for the little bit of mind ease... hehe
Would I have any advantage of going over to OBD1 ??
with my setup...
I'm planning on running a supercharger at the lowest boost on stock block....
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
