PCM Issue/Question?
Old Jul 18, 2011 | 12:30 PM
DAVE00's Avatar
PCM Issue/Question?
Guys,
As most of you know I've been chasing some false knock issues on my car. I have removed the delteq ignition and gone back to stock with a MSD blaster coil and the car seems to run much smoother, however my PCM is still picking up knock (only at idle -950 rpm -1500rpm) and pulling upto 12 deg timing. Here's what I've checked:
KS (new and properly tq'd added some tef tape later to try and desentize it as well)nothing loose - motor mounts, exhaust, alternator, etc...
y pipe and headers not hitting anything (clear of everything)
no loose rockers
LT4 KM installed for several years
ZERO exhaust leaks from CAT forward
ZERO vaccum leaks
Still present with 100+ octane
Injectors flow checked and cleaned
Fuel pressure fine and new pump
The weird part is the PCM won't pickup false knock until the car is warmed up and goes into closed loop. Once that happens the PCM will randomly pick up knock and pull upto 12 deg timing and you can feel the car changing timing and then it will go away and come again randomly. One other thing, is using DataMaster to log the car I am getting "DATA ERR" flashing erratically in the "DATA OK" status indicator up top. I have read this is usally due to noise in the line from a bad gound but all my grounds check out perfectly. Could this be an indication that my PCM has issues? I am trying to see if they two may be linked some how, as I have been chasing this one like crazy.
Old Jul 18, 2011 | 03:05 PM
Mystery Bird's Avatar
Re: PCM Issue/Question?
Cloosed loop only??? Think maybe it has a lean condition in that area?
Old Jul 18, 2011 | 03:07 PM
DAVE00's Avatar
The BLM's are in check around 128-135 (split due to my large LSA at 108). Give a little gas and BLM's level out.
O2s are new and fluctuating fine.
Old Jul 19, 2011 | 06:47 AM
DAVE00's Avatar
Anyone?
Old Jul 22, 2011 | 03:39 AM
97WS6SCharged's Avatar
Are you using a Scanmaster on the car as well? They are known to give Datamaster issues when both are trying to read signals from the PCM.
Old Jul 22, 2011 | 06:28 AM
DAVE00's Avatar
Nope, just TTS Datamaster for reading and Tunercat for Flashing. I'm going t be checking all my grounds again this weekend and also the ALDL port ground and com cable.
Old Jul 23, 2011 | 06:20 AM
Guest47904's Avatar
Guest
Does your SES light work?
Old Jul 23, 2011 | 09:23 AM
DAVE00's Avatar
Yes, it lights up normally during cycle on. No DTC codes are being thrown when scanning it.
Old Jul 23, 2011 | 01:59 PM
Guest47904's Avatar
Guest
To see if it's entire related to going into closed loop try this. Confirm closed loop operation and pulling timing. Shut off the engine and then restart it. For a few moments, it will be in open loop until it gets to closed loop. See if the same thing happens to the timing.
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
