PCM Ground wire not grounded issues?
Old Jun 27, 2011 | 03:27 PM
MeenZ28's Avatar
The ground wire in this photo -
If it was disconnected or not getting a decent surface contact - would that cause the car to not start?
Old Jun 27, 2011 | 03:40 PM
ItsRyan's Avatar
Re: PCM Ground wire not grounded issues?
Yes that is one ground wire to the PCM..Make sure that its grounded on the oil pan bolt.
Old Jun 27, 2011 | 04:30 PM
No, it won't. It may cause possible strange issues, but not starting would not be one of them. Numerous people have found that off and didn't know it. The PCM has numerous grounds.
Old Jun 27, 2011 | 04:53 PM
ItsRyan's Avatar
Yep just looked at my 94 Z28 factory service manual
4 grounds to PCM
A2 - Black & White Wire
C32 - Black & White Wire
A18 - Tan & White Wire
D1 - Tan & White Wire
Old Jun 27, 2011 | 06:01 PM
MeenZ28's Avatar
Ok, just trying to eleminate possiblities. Thank you.
Old Jun 29, 2011 | 10:57 AM
DAVE00's Avatar
No it will not allow the car to start. I had the same exact issue where I forgot to hook up the PCM ground when I replaced the dipstick tube and oilpan gasket and spent over a week trying to figure out why the car wouldn't fire. That was my issue, as when I hooked up the PCM ground the car fired on the first try and ran butter smooth.
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
Scottyboy
Feb 11, 2015 10:28 PM
Injuneer
Dec 15, 2014 09:36 AM
kandied91z
Aug 6, 2002 01:18 AM
ford
Aug 3, 2002 02:39 PM
