pcm/fan question
Old Nov 3, 2009 | 03:12 PM
2manyToyz's Avatar
pcm/fan question
fans were not working and so i ended up tracing to a bad relay(s) by dropping in known good ones (after testing fan function and swapping temp sensor)
my question is what is the feedback mechanism for the pcm to recognize that the fans are or are not working and if it does see that fans are inoperable what kind of other electronic functions get screwed up as a result?
Old Nov 3, 2009 | 03:15 PM
bw_hunter's Avatar
I don't believe there is any feedback loop as you describe. The PCM commands the fans on and 'assumes' they're on. Nothing else should be affected.....
Old Nov 3, 2009 | 03:27 PM
97FormulaWS-6's Avatar
Yea, there is no "feedback" for the PCM to the fans. It just supplys the trigger voltage to the relay; that's it.
Old Nov 3, 2009 | 03:57 PM
There actually is feedback info, but it is just from the PCM to the relays (DTC 77 for OBD-I and DTCs P1641 and P1642 for OBD-II). The PCM monitors those circuits for inappropriate electrical signatures (opens or shorts) .
There are no other consequences of the fans not working, except for the possiblity of higher than normal engine temps.
Old Nov 3, 2009 | 09:09 PM
charliediss's Avatar
You amaze me.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
