Pcm
Old Oct 4, 2003 | 04:40 PM
ead94z28's Avatar
Question Pcm
Will a 94 PCM adjust the air fuel mix to the correct settings if you descreen the MAF and gut the CAT?
Old Oct 4, 2003 | 04:43 PM
Z95m6's Avatar
the removing the car won't effect air fuel fuel ratio, the screen might because the sensor won't read the amount of incoming air correctly but the car should compensate for it.
Old Oct 4, 2003 | 05:47 PM
S.J.S.'s Avatar
You don't need PCM just for that mod. The comp will figure it out.
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
