Passing gear on a 97 z
Old Nov 27, 2003 | 10:49 AM
acslinger2525's Avatar
Does a 97 z with traction control have a passing gear? I think my intire problem is this. It idles rough, and it will only shift manuely and it only does this when it wants too. I remember in my mustang when the passing gear wasnt hooked up, it acted real funny. I did a search and people said that the TPS would cause it to idle wierd and not shift firmly. IS this true or did i just comprehend this wrong?
thanks
Old Nov 27, 2003 | 10:58 AM
Javier97Z28's Avatar
Moderator
Passing gear? You can't "unhook" any of the gears in our cars. Automatics have four forward gears, the 4th is overdrive.. when cruising around 75 mph or so if you punch the gas, it's going to shift down into 3rd.. which I guess you could call your "passing gear"
Old Nov 27, 2003 | 11:02 AM
What i mean is, do i have a cable that does this or is it done electronicaly?
Old Nov 27, 2003 | 11:03 AM
Moderator
Electronically, it's a computer controlled transmission
CARiD
Apr 8, 2015 08:08 AM
ChrisFrez
Mar 22, 2015 09:12 AM
Nostang 96z
Sep 10, 2002 08:54 PM
Nostang 96z
Aug 31, 2002 12:01 PM
