Passenger side plug wires
Old May 18, 2007 | 10:33 PM
damastertechjj's Avatar
What kind of clip is holding the wires to the alternator braket? No lift, Want to what is the easiest way to change the wires?, no problems with the driver side. pics would help a lot
Old May 18, 2007 | 10:40 PM
mrseven's Avatar
Don't have any pics. But there is a plastic clip attacked to something () under the alternator. Pull off the alternator, then feel around on the side of the block. Should be able to feel it down there, maybe even see it. I popped mine open with a screwdriver, then ripped it off (too small for my new MSD wires).
And the easiest way to run them is by unbolting the power steering pump (2 bolts, stick the socket through the holes in the pulley) and pulling it out as far as it will go. Then the boots should fit through.
Oh, and have fun getting at that back wire without jacking the car up.
Old May 18, 2007 | 11:27 PM
shock6906's Avatar
The clip under the alternator is easy to see from under the car. Just put it up on jackstands and take a peek. Taking the belt off helps too.
alex5366
Feb 17, 2015 10:43 PM
Jul 4, 2005 05:00 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
