Passenger Side O2 removal
Old Jun 5, 2018 | 03:55 PM
Zaborg95's Avatar
Hey guys any tips on removing that guy? Car is a 95 z8 automatic. The car was throwing a code 13 and occasionally sputtering at a steady speed. It’ll straighten out after a quick blip of the throttle and Cel turns back off. Worked at it for about 2 hours last night before I had to call it. I checked for burnt connections and loose wires to no avail, so I got a new one sitting on the bench.
Old Jun 5, 2018 | 04:32 PM
DrewHMS97SS's Avatar
Re: Passenger Side O2 removal
It has been so long since I have had to touch the car with stock exhaust. Can you snap a picture?
If I recall, the O2 is pointing up towards the firewall on the top side of the pipe. I think I set the wrench on the O2, then put a 1' 2x4 going up to the wrench to smack with a hammer.
Old Jun 5, 2018 | 06:41 PM
Zaborg95's Avatar
Passenger Side O2 removal-d47db08b-db66-4df7-ab85-c6a93f815d39.jpegPassenger Side O2 removal-431c79df-008b-4fd7-8218-8b09f3f9e7c3.jpeg
Got an o2 socket on it and a breaker bar through about 2 1/2 ft of extensions and a u joint. It’s in there so tight it spread the socket.
Edit: IT WORKED. IT WORKED!
Old Jun 5, 2018 | 07:05 PM
Zaborg95's Avatar
Passenger Side O2 removal-e40d1215-9cc1-47bc-b2e0-dd7106477f89.jpegPassenger Side O2 removal-5df253e1-4964-49dd-afcf-906687cbe675.jpegPassenger Side O2 removal-67f8e517-e1a2-4257-81b0-46192a5b31de.jpegPassenger Side O2 removal-1f118ccf-05e2-4fec-808a-2d7ce4977c74.jpeg
Just Incase anyone else comes across this problem, this worked for me
Old Jun 6, 2018 | 10:31 AM
Nice. O2 sensors tend to need some muscle to get out after they have been there for awhile. Headers make getting to the O2 sensors much easier, but make heat shielding everything much harder.
RealQuick
Oct 9, 2012 07:17 PM
RealQuick
Jan 24, 2012 07:43 PM
RealQuick
Jan 24, 2012 12:59 PM
RealQuick
New England Area
Jan 16, 2012 02:50 PM
RealQuick
Nov 22, 2011 09:25 PM
