jays144
Old Jan 3, 2018 | 02:48 PM
jays144's Avatar
jays144
93 z28 with a 383 stroker need help with starting issue
Old Jan 3, 2018 | 02:50 PM
jays144's Avatar
Re: jays144
no crank no start when jump across the strarter it runs for a sec then stops no lights on the dash no crank when you turn the key
Old Jan 3, 2018 | 03:11 PM
jays144's Avatar
need help
93 Camaro no crank no start
Old Jan 3, 2018 | 03:22 PM
Re: jays144
Welcome to CamaroZ28.com. Usually not a lot of tech help in the "New Member Intro" forum.
I'll move this thread to "LT1 Based Engine Tech" for you.
Sounds like you may have a problem with the ignition switch. When you say "no lights on the dash" do you mean you do not get all the warning lights coming on for a few seconds when you turn the key to "RUN", like you would normally get?
Old Jan 3, 2018 | 03:27 PM
jays144's Avatar
Re: jays144
theres lights on the dash when you turn the key on but will not crank nothing when you turn key all the way got new battery new starter new key and ingnition switch it will run for a sec when you jump across starter but dies
Old Jan 8, 2018 | 03:22 PM
jays144's Avatar
no start no crank need help 1993 z28
turn the key and nothing lights are on the dash radio works jumped across starter and will crank and run for a sec and die put new starter new battery new ignition switch
Old Jan 8, 2018 | 05:24 PM
DrewHMS97SS's Avatar
Re: jays144
Does a security light flash on the dash?
Old Jan 8, 2018 | 06:11 PM
Re: no start no crank need help 1993 z28
jays144 - Please keep responses responses in a single thread. I'll merge this response (post #6) with your existing thread.
Old Jan 8, 2018 | 06:40 PM
Re: jays144
The PASS-Key (VATS) system includes a starter enable relay that has to engage to crank the starter. That relay gets its ground from the PASS-Key decoder module.
Starting schematic - 1993:
http://shbox.com/1/starter_charging_93.jpg
In later years, the relay is called the Theft Deterrent Relay (TDR). The decoder module is called the Theft Deterrent Module (TDM).
PASS-Key schematic - 1995:
http://shbox.com/1/pass_key.jpg
You may have a faulty TDR (also called “starter enable relay" on a 1993).
PASS-Key trouble shooting/repair from Shoebox:
4th Gen LT1 F-Body Tech-PassKey/VATS
Old Jan 9, 2018 | 07:37 AM
jays144's Avatar
Re: jays144
no lights flashing on dash
Old Jun 5, 2018 | 04:25 PM
jays144's Avatar
Re: jays144
no flashing lights on dash you turn key and nothing lights work horns and radio new battery
Old Jun 5, 2018 | 05:04 PM
Re: jays144
The security light should come on, then go out after a second or two. I would start by checking all of your fuses if you are seeing no lights what so ever on the dash. If all of the fuses are good, it sounds like the ignition switch.
Old Jun 5, 2018 | 05:09 PM
jays144's Avatar
Re: jays144
new ignition switch key all lights on then go over turn the key nothing you can jump across starter and it will turn over but wont start
Old Jun 6, 2018 | 10:29 AM
Re: jays144
Did you change the switch on the top of the column under the dash, or the cylinder? It sounds like the cylinder; I would try the switch under the dash.
Old Jun 6, 2018 | 10:37 AM
jays144's Avatar
Re: jays144
cylinder and key
