Passenger door lock is tough to move
Old Jul 20, 2004 | 02:27 PM
Detroit808's Avatar
My passenger side door lock inside the car barely moves with the power switches anymore. I had this problem before, then played around with the lock for about 10 minutes, and it opened and closed easily after that. Now I'm back to the same old problem, and playing with it isn't helping. I thought at first that maybe the switch or motor/actuator was weak, but even moving the lock by hand has a lot more resistance than the driver side. Did anyone else have this problem? I'm thinking something in the door could use some grease.
Old Jul 20, 2004 | 02:48 PM
Camaro94Lover's Avatar
Re: Passenger door lock is tough to move
It could very well need some cleaning on the internal mechanisms. A lot of grime can build up over time and with the factory lube on it, dust will just stick to it. I had the same problem a year ago and took it apart. Cleaned some gunk out and installed component speakers.
Victor Lamb
Aug 26, 2017 02:52 PM
Fastbird93
Apr 9, 2016 07:01 PM
Heathen1
Jan 2, 2016 04:27 PM
