Passenger Carpet Wet?
Old Feb 20, 2004 | 06:44 PM
96lt1Camaro's Avatar
I was running some stereo wires under the carpet on the passenger seat. When i lift up the carpet, the foam under the carpet was soaked!! Could this be the AC problem that some people encountered? Or could there be water leaking in from when it rains. I havent checked the drivers carpet but i hope i dont find it wet when i check it
Old Feb 20, 2004 | 06:48 PM
doodad's Avatar
Does it smell like coolant at all? Could be your heater box going, I have been there and it is not pretty. If you turn on defrost, do you steam up?
Old Feb 20, 2004 | 06:49 PM
On a cold day when i first turn on the DEF yes it steams the windshield then it clears it
Old Feb 20, 2004 | 06:50 PM
961le's Avatar
mine leaked when it rained.i had to replace the weatherstripping around the doors.
My t tops are alos kinda leaking, so most likely is water
Old Feb 20, 2004 | 07:15 PM
bigde4u's Avatar
It may be coming from the t-tops/door. Mine leaks into the back on the drivers side! I would think it would smell like coolant if it was coming from your heater core.
Old Feb 20, 2004 | 07:27 PM
Kataklysm's Avatar
I'd lean towards the heater core.
Old Feb 20, 2004 | 07:50 PM
There is a balck plastic cover covering the firewall, the water seems coming from there. Where is the heater core?
Old Feb 20, 2004 | 07:59 PM
magius231's Avatar
when the heater core goes, typically the steam that hits the window is VERY difficult to get off and makes it halfway impossible to keep the window defrosted. Wipe the window down with a clean paper towel - if it smells like coolant you have heater core issues
Bigfatrat
Parts Wanted
Oct 4, 2015 08:54 PM
football4life
Oct 4, 2015 07:48 AM
WPHIG2
Aug 27, 2015 06:37 AM
POLOVETTE 94
Aug 21, 2015 07:11 PM
Boss002
Jul 9, 2015 03:33 PM
