Bleeding ABS module
Old Feb 20, 2004 | 07:25 PM
convertz's Avatar
Bleeding ABS module
I have been having a mushy brake pedal. I plan on bleeding all the calipers, and checking for mushy hoses, but if this doesnt help how do I bleed the ABS module?
There are bleeder bolts on there, but what order do they go in, and do i need a special tool to get the abs to "pump" while im bleeding?
thanks
-Ted
Old Feb 20, 2004 | 08:10 PM
PatriotTA's Avatar
I saw a thread not too long ago where some guys were saying that once you bleed your brakes you take it out for a spin and lock up the brakes a few times (so the ABS kicks in each time). Then go bleed all 4 brakes again. I can't remember if they said to repeat that or not, but it seemed to work for them. HTH
Formula Steve
Sep 19, 2023 08:31 AM
IndyZman
Oct 22, 2015 02:17 PM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
1bad427ls1
Sep 23, 2015 01:12 AM
