passanger side plug wires?
Old Apr 29, 2003 | 02:43 PM
94droptopz's Avatar
how did you run your wires? im just wondering cause i dont have any wire looms and found one wire rubbing a pulley from the last install of wires.
thanks guys
Old Apr 29, 2003 | 07:46 PM
EvlViln's Avatar
buy the Taylor 409's that are 11mm, and run them over the valve covers, summit will sell you the wires and the wire lumes, and also buy earls flame gaurd so that they dont burn on the header, and dont forget the dielectric grease. Oh, and change you exhaust gaskets.
Old Apr 29, 2003 | 08:18 PM
Bud M's Avatar
Assuming you have aftermarket 8 or 8.5 mm wires, I used a set of Moroso looms (same as M4U or MSD looms) and put a 4 hole one right off the alt. bracket. This keeps them arranged inline to keep them away from the serpentine belt. Also I took my Dremel to the alt. bracket and removed a little material where the curved indentation is and rounded the edge to make the wires sit in place better.
Old Apr 29, 2003 | 08:48 PM
94droptopz's Avatar
i've heard before that its not good to have the wires touching, is this true? i personaly have never had a problem with this but im chashing a miss so i dont want to over look anything.
(id also love to meet the engineer who came up with the opti )
Old Apr 29, 2003 | 09:10 PM
EvlViln's Avatar
touching wires are VERY BAD!
Old Apr 29, 2003 | 09:21 PM
Bud M's Avatar
Where wires touch you would rather have them at an angle to each other, not running parallel.
Old Apr 30, 2003 | 02:55 AM
EvlViln's Avatar
Old Apr 30, 2003 | 04:43 AM
magius231's Avatar
not from what I have heard. I asked thie question not too long ago, and the responses I got indicated that wires running next to each other doesn't cause the crossfiring it used to with old technology wires. The stock wires were run like that in some places too
Old Apr 30, 2003 | 07:58 AM
teke184's Avatar
"touching wires are VERY BAD!"
we get your point...
my question is why does the factory run the wires parralell to each other? granted the factory isn't known for their 100%, flawless inteligance...but...if it's such a BAD thing...and so commonly know i doubt they would do it.
Old May 2, 2003 | 01:13 AM
EvlViln's Avatar
If you are getting me, then why do you keep NOT getting me. The factory wires DO NOT TOUCH. They run in their own little track, they do run parallel, but the wires install by the factory, never touch. There is nothing wrong with Parallel wires as long as they dont touch. And all that BS about wires cross firing being only on old cars, is total crap, i have had it happen to me and many other guys i know using all sorts of different wires from MSD to Accel, the only wires i have NEVER seen arch on each other after much use, are the taylor 409's. But i cant talk to much, i run the MSD's even though they keep arching on me, i for some reason keep hoping they wont, but they always do. I hope this helps.
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
grabbem88
Mar 18, 2015 01:25 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Jazsun
Dec 29, 2014 12:14 PM
