part number for stock GM lifters?
Old Apr 1, 2004 | 11:15 PM
pillagenburn's Avatar
just wondering the p/n for stocker GM LT1 lifters..... gonna do a cam swap and i want to keep stock lifters
prolly XE 224/230 cam and some Advanced Induction heads later ...... combination motorsports cam kit for now though
and LT4 heavy duty timing set
... Comp R lifters are just way too expensive
thanks!
Old Apr 1, 2004 | 11:26 PM
Spinner's Avatar
850-16
Stock lifters are only $10 cheaper for a set then comp Rs
Old Apr 1, 2004 | 11:40 PM
97WS6SCharged's Avatar
12371042 is the GM part number for an OEM lifter kit.
This roller lifter kit is used on all late model V8 blocks 1986 and newer. These second design lifters are used in late model 350 HO engines and use a higher checkball spring preload. This kit includes 16 of P/N 17120735 roller lifters, 8 of P/N 12550002 valve lifter guides, one of P/N 14101116 valve lifter guide retainers, 4 of P/N 24501365 retainer bolts, and 4 of P/N 120386 retainer washers. This kit plus pushrod kit P/N 12371041 and a roller tappet design camshaft will convert your engine to a roller lifters engine.
Price from GM Parts Direct
177.72 + 35.54 (shipping/handling)
Total
$213.26 (NC Residents $225.70)
You can probably find them cheaper if you look though.
Old Apr 2, 2004 | 12:16 AM
Stock GM lifters are not cheap. They make the Comp Rs look like a good value. I would recommend the Comp Rs.
parkers Z28
Mar 11, 2016 08:14 PM
FirebirdGT
Dec 13, 2014 10:25 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
