Part identification
Old Mar 11, 2021 | 12:32 PM
numbr44coldcuts's Avatar
Part identification
What is this part on my valve cover connected to my throttle cable?
Old Mar 11, 2021 | 01:41 PM
RUDEDOG's Avatar
Re: Part identification
Traction Control Actuator
Old Mar 11, 2021 | 02:00 PM
I dont need it. I got traction control tuned out of my PCM.
Old Mar 11, 2021 | 03:36 PM
Technically - "Adjuster - Accelerator Control / Cruise Control Servo Cable"
If it still has the throttle cable attached, meaning the pedal is moving the TCS servo drum and the drum is actuating the throttle, when you delete the TCS servo, you will need a new cable from the pedal assembly to the throttle body. You will also lose cruise control, unless you get a new cable to run from the cruise control module to the throttle body.
Old Mar 14, 2021 | 08:49 PM
I looked for non TCA throttle cables, but of course they are not available anymore. Do I have any options or am I better off leaving it alone?
Old Mar 16, 2021 | 08:04 AM
DrewHMS97SS's Avatar
Check Hawks Motor sports or spend some time in the yards if you really want to delete it.
94magh
Parts Wanted
Mar 19, 2013 05:08 PM
94FBIRD
Buyer/Seller Feedback
Sep 17, 2012 03:39 AM
xxsaint69x
Parts Wanted
Mar 25, 2011 04:17 PM
detroit1994z28
Dec 28, 2007 07:19 PM
$hawn
Jul 13, 2004 09:28 PM
