Pantyhose mod
Old Mar 24, 2004 | 05:47 PM
  #31
joeSS97's Avatar
I prefer using fishnet stockings.I think I picked up a 1/4 hp over the regular nylons.
Old Mar 24, 2004 | 07:40 PM
  #32
EbeZ28's Avatar
Ahhh...common problem. You need to use the panyhose on the car, not yourself.
j/k
Old Apr 20, 2004 | 10:37 AM
  #33
JSK333's Avatar
Just a small update--the increases were due to the mod, and not just the cooler air. I scanned it again in warmer weather (70s F), with IATs in the 30s C, and I still hit 306gps around 5300-5400 RPM.
So, it works! I may put another layer on, to increase filtering.
Old Apr 20, 2004 | 11:32 AM
  #34
badblackta's Avatar
I am using pantyhouse on the end of my k&n cai, and it works fine. I have 3 layers one there, that should filter most of the trash
Old Apr 20, 2004 | 12:03 PM
  #35
gb95zconv's Avatar
Originally posted by MisterGuru
At the track is ok... but, man... a little bit of debri won't be stopped by Leggs and could cost you a MAF sensor :-)
I agree......I see this at the track quite abit and tried it once but saw no gains in mph or et. Filters are made the way they are for a good reason.....ever wonder why you dont see a Leggs display at the parts store
JSK, what kind of engine setup are you running?
Old Apr 20, 2004 | 12:30 PM
  #36
buelldevil's Avatar
I know some one that did the same thing with his third gen. It is great for the track, not the street. Some one stated it is like a vacuum, it is! Combustion engines, in air, add fuel, and push exhust. The person I knew that did the same thing as you are pulled into a parking lot that was covered with dirt, sucked it through the intake, and blew the engine. When he pulled the engine apart, the rings and pistons were covered with oil and SAND!
Old Apr 20, 2004 | 12:50 PM
  #37
JSK333's Avatar
Internally stock engine. I have no doubt it's made a difference, both SOTP, as well as by scanning (increase in airflow). The question is whether it filters enough.
I also do still have my MAF sensor screen intact.
When I check the hose, there are sometimes small pieces of debris, which tells me that it is working somewhat at least.
Old Apr 20, 2004 | 03:32 PM
  #38
gb95zconv's Avatar
Oh Im not doughting what you say......if your engine is internally stock 300+ gps a very good number. On my old hotcam setup I was only able to see 313 gps at best.
I still would only do the pantyhose mod at the track.
Old Apr 22, 2004 | 09:56 PM
  #39
pelebkf's Avatar
Instead of panty hose what about a cloth vacum bag????????????
Mikes 1994 z28
Oct 10, 2015 07:55 AM
DelSoto
Sep 19, 2015 05:31 AM
karpetcm
Sep 15, 2015 11:07 AM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
CARiD
Jul 7, 2015 08:19 AM
