pacesetter LT clearance with canton fabbed valve covers
Ive got edelbrock shorties right now and while my motor is out i wanna put LTs in there, so im getting the pacesetter LT with no air or egr fittings. I bought canton fabbed aluminum valve covers and the shorties on the driver's side come too high up and towards the motor and would hit the valve covers. Im wondering if the pacesetter LT would hit too since the first tube is kinda up and in. Anyone have any pics of the drivers side pacesetter in the car so i can see? Thanks.
In OBD-II the PCM cycles the air pump, and looks at the O2 sensors to see if there is a corresponding air flow. If it doesn't see the air flow, its sets a code/SES light. You have to have the codes programmed out.
) If i just left it on the block and plugged in but not hokked to anything would it still throw on a SES ? THX.
