Pacesetter longtube clearance issues
Old Dec 6, 2004 | 11:51 PM
Firebird355's Avatar
I have the pacesetter LTs on my 96 and the collector on the driver side is so close to the box brace that runs over the the trans crossmember that there is no way i will be able to slip a pipe over it... anyone else have this issue what are you doing about. Any ideas? Thanks - Joel
Old Dec 7, 2004 | 02:47 AM
krispy's Avatar
Re: Pacesetter longtube clearance issues
I think I know what you are talking about, the shop that fabbed up my y-pipe had to have a weird dip in that region and I had a problem with the pipe banging again the body. I fixed that with the good ol hose clamp + rubber hose though. Ill try to get a picture for you tomorrow if I can
Old Dec 7, 2004 | 09:48 AM
brandboZ28's Avatar
Ive heard about a bunch of guys putting a pipe in the collector and pulling it down away from the floorboard to get the y-pipe to slip on.
Old Dec 7, 2004 | 09:59 AM
Formula03's Avatar
Thats how I did it, it worked fine.
Old Dec 7, 2004 | 10:50 AM
Cmr0z28's Avatar
Crease the floorboard inward with a bottle jack. If you don't do something about it, it's going to smack the floorboard every time you press the gas pedal, resulting in insanity.
Old Dec 7, 2004 | 12:04 PM
Z-RATED94's Avatar
Just talked to Speed Inc. a few hours ago. They are also having a few issues with the fitament of my Pacesetter headers and Y pipe. Drivers side is to close to the floor board and the Y pipe is going to need some modification to make it work. It sounded like they had these problems before. I'm just glade they know how to deal with these set-backs.
Old Dec 7, 2004 | 12:59 PM
#7's Avatar
Mine is the same way.I dont know that they are trying to correct the issue and its not just your either. Their solution (as mentioned already) is the Y-pipe they offer w/ the LTs has a depression or is dent in that area of the Y-pipe dealing with the issue.
I believe it is intentional to get the most ground clearance possible. I get a smack on the floor ocassionally.
T.
Old Dec 7, 2004 | 01:04 PM
zx1216's Avatar
Yea, i had a few problems with my set up but i think i got it worked out, my y-pipe didn't fit too well at first so i welded it together and then tacked it onto the headers because it poped off the first time i did a hard 1-2 shift, it works fine now though.
Old Dec 7, 2004 | 02:20 PM
krispy's Avatar
there are pics of my y-pipe, the hose clamp has the rubber hose on it that prevents the knocking
Old Dec 7, 2004 | 04:22 PM
well I posted this because i am thinking about getting the xpipe setup and i was just wondering how all of you have slipped your y-pipe onto it but it looks similar to how mine is right now. I didnt buy the pacesetter y-pipe mine is just custom made. here is a pic of mine, damn things started to rust on me really quick... just the collector area though
http://www.firebird355.michiganspeed.com/DSC00929.JPG
http://www.firebird355.michiganspeed.com/DSC00931.JPG
Old Dec 7, 2004 | 04:24 PM
krispy's Avatar
Are those supposed to be coated? If so, how long have you had them on the car
Old Dec 7, 2004 | 04:59 PM
BRENTT94Z's Avatar
Just recently puchased the Pacesetter LT's ceramic coated w/ out emissions.
Installed them when I Installed the new motor, so it was much easier. I even bought the locking header bolts, thinking I wouldnt have to worry about header leaks anymore. On the other hand I wasnt that lucky, Started the car this weekend and turns out I have .15 gap between the header flange and the head, and the header bolts are bolted as tight as they will go. Turns out after taking them back off, the flange had a **** pour surface. Around the bolt holes their is a hump at every bolt hole where they have been in the drill press When you purchase these headers you need to make sure the flange surface is flat, not sure if anyone else has had this problem or if its just me but apperently I got a bad set. Just dont want to have to go through the same problem I went through. All I did was grind down the humps, and its fine now.
Depending on what y pipe you use youll have a clearance issue on the driver side about 3" past the collector on the body cross brace. All I did was slightly dent the pipe a bit more. Sorry for the long chapter of a thread I wrote but I hope it helps.
You can check out my cardomain I have a few pics of the motor before Installed.
http://www.cardomain.com/memberpage/573287
Brentt
Old Dec 8, 2004 | 01:50 AM
nah they werent ceramic, they were black and i stripped them down and sprayed about 3 coats of 1200 degree aluminum color paint... they have only been on there since late september. Yea im pretty upset about that heh, its not rusted up top just down there heh.... oh well they were just cheapies heh
Old Dec 8, 2004 | 10:45 PM
Sunsceamer's Avatar
I have the same flange to head leak. I also welded flanges to the collector so the y pipe doesnt slpi off as easy.
Old Dec 9, 2004 | 02:18 PM
IEAT50Z's Avatar
When I installed a set of these, I had a similar problem. I just took a sledge to the floorboard and banged the hell out of it. The floorboards are double sided so you wouldn't ever notice it until you were under the car.
WildRidez
Mar 27, 2015 08:22 AM
camaro98_speed
Wheels and Tires
Mar 17, 2015 07:36 AM
Jazsun
Dec 29, 2014 12:14 PM
'01BlackZ
Sep 3, 2002 09:53 PM
