Pacesetter Headers: First Impressions
Old May 19, 2005 | 10:04 AM
  #16
BadIroc's Avatar
Re: Pacesetter Headers: First Impressions
Originally Posted by steves97z28
that was my car after a few minior problems, not with the headers just my ****ty luck, i spent all my money on the headers and then the week later the opti went any ways the car hasnt caught fire yet lol even though they are close it hasnt been a problem. to stop the rubbing i used a peice of hard rubber i found on the ground
Sounds good Steve, glad things are working out for ya! Anxious to see what the new numbers are gonna be.
Old May 19, 2005 | 12:54 PM
  #17
steves97z28's Avatar
well those numbers were better then the "new numbers" after the opti install and tuned pcm, it mad 4 less rwhp. havnt been back since, but i dont feel the car is making all the power it should be. got to check my fuel pressure.
Old May 19, 2005 | 01:40 PM
  #18
slomarao's Avatar
Did u guys have to jack up the motor to get them in? You guys mentioned the good ground clearence, how the the install? Those the 2 things i am looking at.
Old May 19, 2005 | 02:09 PM
  #19
RealQuick's Avatar
Driver's side went in from the top because the head was off (broke rust exh. manifold bolt in the head). Passenger side need to be jacked up to go in.
Old May 19, 2005 | 02:14 PM
  #20
1quickTA's Avatar
I have the same set up, Pacesetter LT and ORP with Hooker catback and I couldn't be happier. The fit is awesome and the souund is badass. The only thing I am not sure about is my idle is sort of odd sometimes after the install (I also pulled my intake during the same time as the header install for another reason). If I am cruising and I shift into neutral and/or hold the clutch in, the revs sometimes climb up to about 2,000 and dont settle until I slow to a stop. I posted about this before and got no response. Any suggestions?
Old May 19, 2005 | 02:52 PM
  #21
matLT1's Avatar
I'd check for vacuum leaks and make sure all hoses were put back on the intake properly.
Old May 19, 2005 | 03:39 PM
  #22
DiabloGT's Avatar
would you guys go with no cats with the ory and pacesetter lts and slp lm? or add cats, emissions are not an issue for me... so would it sound like crap... or add hi flow cats
Old May 19, 2005 | 03:45 PM
  #23
My Iroc Z28's Avatar
mine sounds great, i have pacesetter LT's with the ory & the LM it will draw alot of attention and sound like your at WOT when your crusing @ 3k so beware of local cops.. and about the cats i have some what of a rasp not alot and not annoying but im feel like i lost my low end grunt due to the no cat issue so im thinking about adding 2 high flows into the y and see what happens. but that will also quiet it down some also.
Old May 19, 2005 | 04:04 PM
  #24
fragenstein's Avatar
How do you check for a leak.. and what would it do to performance if there were a leak? I may have this problem sometimes also.
Old May 19, 2005 | 04:14 PM
  #25
DiabloGT's Avatar
if you had a choice to have a hi flow cat in the beginning would you pick it or no?
Old May 19, 2005 | 05:40 PM
  #26
to be honest if you have no emissions then no throw in some o2sims and be done with it, here in MI we don't but if i was ever to go back to ILL then i would need them, also i found my power loss my timing is being pull almost 10 degrees due to the loudness of the set up, so im gonna throw in a LT4 km and see if things change. then i will decide on the cats or not i love the loudness and the complements, and i think the cats will kill the sound, but your car will turn alot of heads. i hope i answered you questions
Old May 19, 2005 | 06:08 PM
  #27
Jono's Avatar
I'm hearing alot of good things about these headers, I'll probably pick up a pair one of these days, but I'm going to still need my cats, it there a Y-pipe I can buy that I can use with my cats or will I have to have one made up?
Originally Posted by RealQuick
Very noticeable power gain and he can now spin the tires from a roll in 1st gear and break them loose going into 2nd gear (which he couldnt do before). Overall, thumbs up for Pacesetter.
Jon
Is my car a freak? Becuase it's stock and I can fishtail into 3rd gear, I thought that was normal until reading his car could only break the tires loose going into second after the header install.
Old May 19, 2005 | 06:10 PM
  #28
Maybe ur tires are crappy.
Old May 19, 2005 | 06:13 PM
  #29
Jono's Avatar
It would fishtail into third with the old 245's (they still had tread and where good tires). With my new tires, 295's Toyo proxy TS-1's, it still lays rubber into third.
Old May 19, 2005 | 06:18 PM
  #30
Do you shift real hard? I can't tell when I lose traction unless I am realllly going sideways... my exhaust is loud enough I can't even hear my tires in 1st.
