pac1218 failure
Old Apr 2, 2008 | 07:46 AM
  #31
maverickmk's Avatar
Originally Posted by krillformula
And yes I did heat cycle them to operating temperature atleast 3-4 times before I even took the first road test.
I will try to get my batch reference number later today..
did you install those springs yourself? did you compress the crap out of them when you (or whoever) installed them?
Old Apr 2, 2008 | 09:03 AM
  #32
krillformula's Avatar
Yes I installed the springs myself and there was no need for me to compress the crap out of them because the new valve seals hold the valve up in closed position and I didnt compress them more than just enough to put the locks in.
I used a tool similar to the crane.
Old Apr 2, 2008 | 09:08 AM
  #33
Patch reference number is: 30631
Old Apr 2, 2008 | 09:55 AM
  #34
19z28camaro02's Avatar
sweet, my batch 63125 hopefully I'm in the clear.
Old Apr 2, 2008 | 10:06 AM
  #35
Good I hope you wont have any problems.
I have been talking to PAC and Im gonna send the broken spring to them for analysis.
Old Apr 2, 2008 | 10:36 AM
  #36
94zgreenmachine's Avatar
I dont think you have to be worried, it´s alot of people running the LE2 heads/cam with the 1218 springs..
I am running the older set of Comp 918 at max lift for the spring. I spun mine high, even pegging the factory tach. All I got was a broken Comp R lifter.
Old Apr 2, 2008 | 12:25 PM
  #37
Originally Posted by Joe Urban
What was your installed height? On another thread recently installed height seemed to be very important. If it is too high there might be valve control issues and if it is too low there could be solid height issues. From the pictures it looks like the broken spring is close to solid height. That might just be how the coils stacked up after one broke. Also from that thread there was some discussion of pushrod length. You might want to recheck that yours is correct.
From what I have read, closing a spring down to solid height prior to installing it doesn't hurt it. Some spring makers do that to every spring as part of the manufacturing process.
I'm glad your broken spring didn't cause too much damage.
Good luck.
Joe Urban
Installed height was 1.75"
And I will for sure check my valvetrain geometry again once I recieve the new parts.
Old Apr 2, 2008 | 02:22 PM
  #38
Thumbs up
Update:
PAC is really taking this serious and I have a new set of springs on the way to me and my broken one is on the way to their lab for analysis.
Lets just say I am very pleased with PAC and their customer service
Old Apr 2, 2008 | 02:28 PM
  #39
dangalla's Avatar
Update:
thats great and i am really glad to hear that. i have heard they have good customer service and that is one of the reason i usually recomend them
Old Apr 2, 2008 | 02:34 PM
  #40
Yes, it feels really great to deal with people who really stands behind their product and I will also continue to recomend them!
Old Apr 2, 2008 | 02:35 PM
  #41
rickreeves1's Avatar
Originally Posted by rickreeves1
So are the PAC 1518's any better or is this just a issolated quality issue with one spring?
Are the PAC 1518's stronger? Less chance of breakage or are they just able to handle some extra lift?
Old Apr 2, 2008 | 02:41 PM
  #42
dangalla's Avatar
http://www.pacracing.com/Valve_Sprin...e_Springs.html
Old Apr 2, 2008 | 02:57 PM
  #43
I'm not too familiar with metal terminology but I'm guessing Premium Nitrided is a hardening process were the 1518's are made stronger. Could these also prevent the problems some are having with valve float? If so the extra $141 would be worth it. I'm asking because I will eventually be looking for some beehives.
Old Apr 2, 2008 | 03:48 PM
  #44
maverickmk's Avatar
Update:
FWIW - I had bought a set of Comp Beehive springs from another member of this site, the 918's that everyone has been talking about here - after I received them is when I started to realize the problems some people on here were having. I contacted Comp Cams and told them I thought I had a set of the bad springs. They asked me if I knew the batch number, which I didn't, and they sent me a new set and took the old set back - no other questions asked. Just seems that Comp has been getting some bad press here lately and I wanted people to know they took care of me as well. Sorry for stepping on your thread.
Old Apr 2, 2008 | 04:02 PM
  #45
No problem, its good to know what companies you can trust!
