PA lower A arms vs BMR lower A arms
Old 02-15-2004, 12:00 PM
slider's Avatar
Any reason why I shouldn't go with PA lower A arms?
Would it be fine to use a BMR K member and PA lower A arms?
slider is offline
Old 02-15-2004, 04:54 PM
Steve0's Avatar
You should probably try the Auto-X section. Theres a lot of really knowledgable guys in there.
Steve0 is offline
Old 02-15-2004, 05:00 PM
Advanced Member
Heatmaker's Avatar
theres an auto x section....now
tzight
Heatmaker is offline
Old 02-15-2004, 11:24 PM
slider's Avatar
No replies there and not many views. This isn't an autox car, though. I just wanted to do the A arms while I am doing the K member
slider is offline
Old 02-15-2004, 11:26 PM
InjectedSS's Avatar
DUDE BMR is the $HIT... NUFF SAID!! What kinda kmember do you have? A BMR I hope, is so then go with the BMR ones.. If you have a PA kmember then get the PA ones...
InjectedSS is offline
Old 02-16-2004, 12:16 AM
RedHottG2's Avatar
I would recommend doing everything BMR...IMO they make the best stuff for our cars hands down!!
RedHottG2 is offline
Old 02-16-2004, 07:48 AM
IDOXLR8's Avatar
You may want to do a search. I have heard of many people having problems with alignment when going to Lower A-Arms.
IDOXLR8 is offline
Old 02-16-2004, 09:38 AM
RacinLT1's Avatar
you can mix and match. i have a few friends that have done it and no problems at all. PA stuff works.
RacinLT1 is offline
Old 02-17-2004, 04:35 PM
slider's Avatar
I can get a new set of PA lower A arms for 1/2 the price of a set of BMRs.
So should I go with those and the BMR k member? I am definately going with the BMR k member.
slider is offline
Old 02-17-2004, 04:57 PM
simple's Avatar
i would think thats because they dont get the rod ends extended to the right length
i just layed my BMR lowers over the stock lowers and made my adjustments that way also had the aid of a tape measure
if you use the same locations for each set of arms to take a measurement from you should be fine with an aligment afterwards, it is a lil tuffer to find a place to actually do the alignment
simple is offline
Bobczar
10-23-2015 11:22 AM
gelbza
07-12-2015 08:10 AM
SergheiS
07-05-2015 03:27 AM
Noer
Parts Wanted
07-04-2015 05:13 PM
Quick Reply: PA lower A arms vs BMR lower A arms
