P1441 - manufacturer control. aux emission controls?
Old Mar 17, 2008 | 07:43 AM
silver97Z's Avatar
Question P1441 - manufacturer control. aux emission controls?
Is this the same problem that's mentioned here? https://www.camaroz28.com/forums/sho...ighlight=P1441
If not, has anyone else had this code?
Old Mar 17, 2008 | 11:49 AM
96flame's Avatar
Canister purge flow when not commanded. Most common cause is the purge solenoid stuck open from a charcoal cannister starting to break up.
Old Mar 17, 2008 | 12:47 PM
silver97Z's Avatar
Thanks 96.
I just noticed I put this in the wrong forum...if someone wants to move it that would be great. Thanks.
Old Mar 17, 2008 | 02:25 PM
Pontiac_97's Avatar
could also be a vacuum leak at the purge solenoid. i had the same code, i replaced the cansiter and solenoid and it still came back. i ended up zip tieing the two vacuum hoses to the solenoid and that solved my problem
Old Mar 17, 2008 | 04:32 PM
Can also set if you have the two hoses on the solenoid reversed. Check it per Shoebox's photo:
http://shbox.com/1/evap_sol.jpg
sherwinZ28
11
Aug 15, 2015 05:38 PM
karpetcm
Aug 14, 2015 03:02 PM
Chevyguy358
Parts Wanted
Jul 20, 2015 07:42 PM
Jul 17, 2015 02:47 PM
Jul 10, 2015 02:23 PM
