P1351 / DTC 41 ICM circuit (Open or Shorted)
I took the following steps when diagnosing my car, using a chart I was given: (1996 Chevrolet Camaro Z28)
1.) When you clear the DTC does it come back on immediately?
YES
2.) Check voltage @ Terminal B on the ICM harness connector with ignition on, is there more than .5 volts?
NO….. .05 - .1 volts
3.) Voltmeter on AC scale, crank engine and observe voltage @ Terminal B on the ICM harness conector. Is it between 1 and 4 volts?
YES ……. 1.2 – 2.4 volts
4.) Ignition off, Probe (with positive) ICM harness connector @ Terminal C, should have voltage.
YES the ground is good for the ICM.
CONCLUSION………….. I am finishing up the test, will have results soon.
EDITED: I edited before, i thought it was the ground, but tested it wrong.
Trying to cure this problem and get rid of the code, thanks.
YES
Something is wrong with that diagnostic tree. Terminal C of the ICM is the ground, so there should be no voltage on that wire. You should be checking for system voltage on terminal A with the key ON. The ground for the ICM is right there on the coil mounting stud.
My fault, its suppose to be, probe the C Terminal with positive and see if the ground is good, which I did and it is good, fixin to do the rest of the tests.
Here's a link to it:
http://www.yousendit.com/transfer.ph...E7363F25D4FBA8
any chance you would have that diagram? Or could possibly modify that PDF to show me how it should be done? maybe in an image? thanks, this is what I need, that would really help me pinpoint the problem.
So that chart is no good for me? all the wires and everything match up, but i know the OBDI has a different coil pack.
1996LT1Z28
Apr 14, 2015 07:15 PM
Decromin
Aug 18, 2002 10:11 AM
Redbird
Aug 13, 2002 03:29 PM
