roller rocker a scared up on bottom
Old Jun 11, 2007 | 07:47 PM
ayers1967's Avatar
I look at all the old post but didn"t find it . Some one had posted on here and had a picture of a roller rock all scared up . Was wondering what the found out . Mine has about 2 hours on it now and it did the samething.Can anyone tell me what the installed valve height is on stock alum. head. Thanks.
Old Jul 6, 2007 | 02:39 PM
WhyHelloOfficer's Avatar
Is that the picture?
That was about 6 months ago when my rockers weren't properly adjusted and my nitrous leaned out too much, so I had a pretty decent backfire that ended up causing the rocker to go sideways on the valve.
Are you positive you adjusted the rockers properly? If you're not positive you haven't, then I'd suggest going back through and readjusting them to be sure.
Follow this guide, it'll save you a huge headache:
http://shbox.com/1/4th_gen_tech2.html#adjust_valves
Old Jul 6, 2007 | 02:51 PM
jsetzer's Avatar
I've seen Crane Golds rub on the bottom of the studs before, is that your problem?
Old Jul 6, 2007 | 03:02 PM
Don 97 SS's Avatar
I had one of my expensive Crower ss self-aligning RR jump out of position once. It eventually beat the lock and retainer until the valve dropped. I never did determine the cause of it jumping, but no more self-aligning RRs for me.
It is a good thing you caught that problem early.
Old Jul 8, 2007 | 09:25 PM
Severous01's Avatar
you might need new pushrods...probably shorter.
Old Jul 9, 2007 | 07:56 AM
Revolutionary's Avatar
A lot of the time the roller rockers will rub the retainer just a little bit instead of riding completely on the valve tip. If that is the case then about the only thing you can do is to use some -.050 valve locks to extend the valve tip and make sure your springs will still work correctly. I just fixed this on a customers engine with three roller rockers chewed up. Make sure you can slide a piece of paper between the rocker and the retainer for clearance
Nutty's96
Dec 21, 2015 06:25 AM
Slayer
Aug 17, 2015 03:55 PM
Mir Hussain
Outside of United States
Aug 8, 2015 07:00 PM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
